Old June 26th 2005, 19:00
VEEMAN VEEMAN is offline
944 Ali A arms into 03
I have a chance to purchase a pair of Ali A arns off an 1986 944. My question is, is it possible to use the drive shafts off an 924? I have the 901 dog leg box fitted to the 03 at the moment. the inboard CVJ is off a T4 transporter fitted with standard 03 CVJ on the A frame end. These joints are fitted onto the 924 splined shaft.
So is the above combination I've fitted already suitable to do the straight swap to the Ali Porsche 944 A arms.
Any one done this conversion with the drive shafts I've got fitted at the moment can clarify it will work or won't. I don't want to swap the driveshafts off the 924 if I can use them.
Any help would be appreciated.
Cheers
VEEMAN
Old August 1st 2005, 16:07
MattKab's Avatar
MattKab MattKab is offline
You're easiest route to fitting the Alu 'arms would be to use the shafts/CV's off the same car ('86 & '87-'9x) The hubflanges in the Alu arms are specific. But they have the same bolt pcd as your 901 outputflanges/944/T2/T4.
The 924 shafts are the same length as T1.
Matt
Old August 1st 2005, 16:10
MattKab's Avatar
'Forgot to mention, the Alu arms need shafts that are a good few cm's longer.
Matt
Old August 1st 2005, 16:18
MattKab's Avatar
Just read the other post
Old August 2nd 2005, 07:24
yetibone's Avatar
yetibone yetibone is offline
Use axles from an '86 951, or an '87+ 944S.
They have Type II CV's bolt pattern, and are 21.5 inches long.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old August 3rd 2005, 14:39
effvee effvee is offline
Which is the earlier model
Hi, how much further does the Alum, trailing arm stick out for the earlier when comparing to later model?
