Old August 6th 2005, 17:30
lazylongboarder's Avatar
lazylongboarder lazylongboarder is offline
Custom made coil over shocks
I have two differant plans for coil over shocks, both would be great setups.
Option #1:
Bilstein Oem rear shocks for the IRS beetle=$70
Bilstein Oem front shocks stem mount for a 69 camaro (similar valving to the balljoint beetle but a smaller shock body according to bilstein[don't ask])=$74
Snap rings for both sets of shocks=$5
Coilover sleeve kit by AFCO (5" of ride height adjustability on shock!) from summit racing=$40 per shock
Total front and rear coil over setup ride height adjustable only=$695 minus machining for Snap rings.
Option #2:
Aldan coil over custom made to my specs, single adjustable, ride height adjustable, heim joint bottom mount, stem mount top for ball joint beetle=$420 with all hardware and springs.
Aldan coil over shocks heim joint coil overs double adjustable, ride height adjustable=$530 with all hardware and springs. (Single adjustable, ride height adjustable=$399)
Total front and rear coil over setup fully adjustable compression, rebound and ride height=$950 complete, $820 single adjustable, ride height adjustable.
1974 type 1
Turbo 6 piston brakes at all corners
Project is taking all my money and it's all Germanlook.com's fault!
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
Old March 12th 2006, 02:55
Mikey's Avatar
Mikey Mikey is offline
Where can I find info on Aldan shocks?
Thanks,
Mike
'04 R32 Tornado Red
Old March 12th 2006, 03:00
Mikey's Avatar
www.aldaneagle.com ???
Mike
'04 R32 Tornado Red
Old April 24th 2006, 02:30
kleinporsche kleinporsche is offline
Lazy, any picture or further info on option 1: camar bilstein coilover mod. Is it really easy to carry the modification? cutting or welding? thanks
A tech article on this would be great. You said you can ajust the ride height by 5"!?!: how does it work?
thanks
Old May 8th 2006, 19:08
bump! Any news from Lazy?
