Old August 9th 2005, 10:49
hugovw1976's Avatar
hugovw1976 hugovw1976 is offline
Audi Quattro Transmission
Some one know how eliminate or cancel the center diferential of one of this transmission?
VW 1976
Old August 11th 2005, 11:56
BOBTAIL BOBTAIL is offline
I seem to recall if its an early trans with the vacuum operated lock you can just fix it engaged with a piece of wire.
Old October 23rd 2005, 23:11
Ian66 Ian66 is offline
I was looking at this box too and though hmmm.. I wonder if it could be made to fit a vw and still maintain a rear engine (not mid engine) configuration.
Can anyone confirm that?
I guess the diff would need to be swapped over to the other side of the box and of course the center diff disconnected.
Cheers,
Ian
Old November 16th 2005, 19:23
wahdubi wahdubi is offline
swop da diff
The early audi trans can be made to work in a beetle and all early and late share the same bolt pattern but only the early type to 80 if I remember correctly is worth the trouble. the later type trans has too many difficulties to make it a worth while proposition. It is a very strong trans and if you manage to hook up the shifter mechanism without going nuts then let me know please. Oh by the way the gear ratios are ok but 4th is a little low
