Old January 21st 2006, 23:00
EvilOval EvilOval is offline
Garage sale Bug Super T4 911 and 944 Stuff
MISC PARTS:
-14mm Porsche press-in wheel studs ((10 only)) $20
-911 Head light lens ((only 1)) but it is brand new $10
-ProCar set rails in great condition, these are meant for pre 72' bugs (driver and passenger available) $50 a set
-VW Beetle Custom Handbook 'Revised and Updated" $10
-Super Beetle 74-up control arms with brand new ball joints and Urethane bushings from Topline Parts $85
-Topline Parts Urethane sway bar bushings (for HD Bars on Supers) $5 per set
-Urethane spring plate bushings $15
-71 or 72 Super Beetle Gas tank in great condition $15
-1 set of brand new upper/lower ball joints (enough to do your front end) $45
-(1) 17"x7" Sport Classic Porsche wheel wheel with 55mm offset $100
TYPE IV AND 911 PARTS:
-200mm Conversion flywheel. It allows you to use a Type I clutch and pressure plate in an upright conversion. Purchased from the Type IV store and just mounted to the engine ((NEVER RAN)). $200
-Fat Performance Type IV pulley for the 911 conversion. Brand new never installed on the engine. Its black with applied #'s for timing $20
-BAS Type IV pulley for the 911 conversion. Brand new with applied timing strip (hasn't been applied) $20
-Bosch Dual Vac dist from a 1.8 P/N is 022 905 205 in good shape $10
-Used Oil Coolers in good shape (2 available) $15ea
-Instrument Bezel from a 914 in excellent condition $5
-2.0 914 cylinder head tin $25
-11 blade cooling fan in ok condition $50
-(2) 911 alternator pulleys $5ea
-Dip stick from a 2.0 914 engine "FREE"
-Dist clamps (2 available) "FREE"
-911 alternators (2 available....but I have no info on them) $40ea
TYPE I PARTS:
-Billet distributor clamps (2 available) $5ea
-Billet fuel pump block off $5
-Pressure Adjustment kit (brand new still in the package) $5
-6" Power pulley (Santana Style) w/red engraved timing strip (new) $15
-Oil Cooler block off plate ((from Aircooled.net)) brand new can be used on T1 as well as T4 engines $10
-Aircleaners, linkage bar and misc parts for Dellorto Carbs $40
-Dellorto or Weber dual port manifolds $15
-8mm spark plug wires ((brand new still in the package)) $10
-Electronic ignition module ((brand new looks like a compu-fire kit)) $45
944 PARTS:
-Turbo front hub (only 1) $10
-83 to 85-1/2 front dust covers ((brand new)) $30
Shipping is available, please send me your zip code with your email. If you have a preference with a shipping company please let me know in your email. If your local feel free to come by ad pick up the parts.
72' 1302 Vert GL (T4 powered money pit)
69' Ghia GL (T1 turbo powered and in pieces)
Old January 22nd 2006, 01:18
Scotts73SB's Avatar
Hey Evil-
Requesting a picture of...
Thanks!
Old January 22nd 2006, 02:15
Here is a pic of the wheel http://www.thesamba.com/vw/classifie....php?id=266875 Let me know if you want it.
Old January 22nd 2006, 23:35
Scotts73SB's Avatar
Very nice wheel but im still trying to get my cups.. thanks for the pic
Old January 24th 2006, 20:24
Ti-Guy Ti-Guy is offline
Email send for Type 4 parts.
Old January 25th 2006, 14:26
TOW74 TOW74 is offline
EvilOval,
Can send some pics of the type 4 911 parts to me at supavert@yahoo.com. I realy would like to see the 11 blade porsche fan. EvilOval, by the way how is the porsche brake set-up working for you? please let me know because I am still in the process of completing mine. please don't forget the pics. Thanks, TOW74, Peace!
