Old May 25th 2006, 19:25
kleinporsche kleinporsche is offline
IRS Swap $$$$
I have a 1974 standard bug with swing axle and I want to go to IRS. How big a hole in my poket am I up to with hardware and labor? Also does anybody know what are the specs for the european 1303s gearboxes. I've heard they are the best vw irs 4 speed boxes but I guess we don't have those in north america, in particular Canada!
Any piece of advise? Obvviously I have to do a pan off.
Old May 25th 2006, 22:06
oasis's Avatar
oasis oasis is offline
I am flabbergasted that Canada got swing axles after 1969 and the US didn't ... unless your car is European-spec (1300cc) or Mexican. This is also the first time I ever heard there were multiple IRS's. I don't want to sound disrespectful because I may just be learning something new, but are sure there are multiple IRS's?
It was my understanding when I was eye-balling a '57 (swing axle) for purchase, the switch to IRS would have required an pan switch and some very minor one-off trimming and welding. The '57 sold before I could align my ducks but that was all I was told.
If my info is short of the mark, I welcome the experts to chime in. The '57 was a brief attention distractor from my Super quest at the time. None of my other distractions involved a swing axle standard Beetle so my info gathering was brief.
Old May 25th 2006, 22:21
If you do the labor yourself then it will be about $500 or so, including rebuilt stock IRS tranny. You can get alot of the parts from www2.cip1.com in Canada. If someone else does the labor $$$$$ . The more you can do the cheaper it will be on labor. Ideally you should give the person doing the work just the pan, weld-in mounts, trailing arms, torsion bars, torsion end caps,and spring plates. The hardest part of the swap is alining the trailing arms for propper camber and toe in before welding everything up.
I have the entire stock IRS set-up on the floor in my shop right now. I went the late model 944 ali set-up with 944 torsion bars, end caps, two piece spring plates, axles, CVs, trailing arms, and turbo brakes.
Old May 25th 2006, 22:37
Mikey's Avatar
Mikey Mikey is offline
In my opinion, the easiest thing to do would be to swap your swing-axle chassis for a IRS. If you're looking at replacing the floor pans, you can fix the IRS chassis up (pans, clean/paint) then set the body on it. But if you change chassis you'd have to weld your vin number in under the rear seat.
As for wrench's estamate. I'd say that sounds pretty close. I've done a lot of welding on vws, but I havn't converted a swing-axle to IRS. My Ghia's body is a '64 which originaly came with swing, but when I bought the car, it was sitting on a '74 chassis, IRS.
Another thought, Ghia's and bugs have the same chassis (tunnel). The differance is in the floor pans. If you can find an IRS Ghia chassis. Use that and put new pans in it.
Mike
'04 R32 Tornado Red
Old May 26th 2006, 04:50
aartjan's Avatar
aartjan aartjan is offline
http://www.germanlook.com/Forums/sho...p=15#post49887
Old May 26th 2006, 20:08
Panelfantastic's Avatar
Hey Aartjan,
What will you take for that setup jig you made? Probably cost as much to ship to me as buying an IRS pan locally though...
Theres also similar info here;
http://www.blindchickenracing.com/Ho...conversion.htm
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old May 27th 2006, 10:13
I wonder also if you could ship the set up. Where are you located Artijian? I hate the idea of tossing my current frame and floors since it's pretty much the only thing that doesn't need to be changed. Everything is falling appart on this car! But I love it. It's been my first car, bougth it back and on it's way to german look!
BTW Oasis, there is no mulpliple IRS boxes per say, but some beetle editions had different gear ratio. The reason I was talking about the 1303s and beetle gt is because the 4th gear has a higher gear ratio: better for crusing on the highway since better top speed. Of course you can just buy new gears but if it all comes in one package and it is less expenssive... This leads me to an other question: what is the gear ratio of the 1303s and gt boxes? Am I mistaking in thinking that 1303s is IRS and GT is Swing axle?
Old May 27th 2006, 23:31
Bruce2 Bruce2 is offline
Originally Posted by Panelfantastic
Hey Aartjan,
Take a look at the last pic on this page. Notice how the guy didn't even bother to clean away the rust and dirt before he welded in the bracket? That's the sign of a true craftsman.
