Old August 4th 2006, 17:54
bt1211 bt1211 is offline
What Axles do I use for late 944 arms?
Hello,
I have put 87 944 arms on my Ghia. The two sets of axles that I have are too short. The Thing axles are about 19" long, I need appox 21". What are my options? I have the CVs. I know that I can get 911 axles in 21 but I believe that the 911 has a different spline count and they are expensive.
What have other people done?
Bryan
Old August 4th 2006, 21:23
levi20AE's Avatar
levi20AE levi20AE is offline
I'm also curious to see which axles are right for this setup. I recently purchased a complete rear suspension from a 87 944. It came complete with everything but the axles and CV joints. will be used on a beetle though.
70 Std. Beetle
03 20th Annv. GTI
Old August 4th 2006, 21:25
You have my answer about axle's already(email). I'm wondering what offset your wells are. The late ali arms add quite a bit of track.
Old August 4th 2006, 22:49
jrinlv jrinlv is offline
I thought the idea of a board was to share info? Unless you are scared of being sued, could your post "your best guess". Thanks.....JR
Old August 4th 2006, 23:15
944 axle w/CV's measure 21" . Sorry, I answered a email earlier today from bt1211 thats why I didn't post.
Old August 4th 2006, 23:44
My wheels are BIG. I am using 8jx 16 et52's. I have made custom QP's for my Ghia. I'll post when I get some pics.
Wrenchnride
Thanks for your reply. In your pic, your axle bolts thru your hub. Mine does not. I have stub axles. What year are your parts from?
I am not 100% sure what year my parts are from, I bought them from a friend, and he was not sure what year they were.
Does anyone know what year uses 21" axles and is the spline count the same?
I also had a question about the lower shock mount. That seems to be a large bolt that fits in there. That bolt would be too large to fit the bottom of a shock. Does the 944 have a step-down bolt? Or a better question would be, What kind of lower shock bolt does a late 944 use?
JR
Thats why I always post whenever I email someone. I have learned more from "lurking" than askings.
Old August 5th 2006, 09:34
yetibone's Avatar
yetibone yetibone is offline
Use 87 and later 944 axles They work with stock CV joints. 951 axles won't work with Type I CV's, as they have a coarser spline pattern.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old August 5th 2006, 15:27
DORIGTT's Avatar
DORIGTT DORIGTT is offline
[QUOTE=bt1211]My wheels are BIG. I am using 8jx 16 et52's. I have made custom QP's for my Ghia. I'll post when I get some pics.QUOTE]
WHAT THE HECK ARE YOU WAITIN FO FOOL! POST THEM THAR PICS
