Old January 6th 2007, 06:29
kendy's Avatar
kendy kendy is offline
`72 1302 lowering
I want to lower my `72 1302 bug
I have lowered springs (8cm) but cant find shocks
1303 owners can use Rabbit shocks but in 1302 cant be used
Do you know what type of shocks can i use?
Thanks for help
k.
Best Regards
kendy
Old January 6th 2007, 06:37
1303R's Avatar
1303R 1303R is offline
hey, with 8cm lowering your gonna need shorter struts not jus different shocks.
Old January 6th 2007, 08:15
kendy's Avatar
can i do it 'home-alone' or have i buy it?
does it mean that standard shock absorber doesnt 'touch' the down of column hole?
how can i do it?
Best Regards
kendy
Old January 6th 2007, 17:27
1303R's Avatar
wether or not you can do it yourself depens on how good you can fabricate and weld, and how good your understanding of mechanics is. if you have too ask then prob better to buy some. I tryed using my car (early 1303) with about 85mm lowered front and standard struts and was real bad, bottoming out on every little bump, jus plain dangerous imo. also worth noting is the angle of track control arm. too low and it points up at the wheel end, not good. there's plenty of people out there with lowered 1302's 3's. so can be done.
Old January 6th 2007, 17:56
peter.holm peter.holm is offline
This is how I lowered my 72 vert:
http://www.thesamba.com/vw/forum/viewtopic.php?t=211928
// Peter
Old January 7th 2007, 10:00
kendy's Avatar
Good work
Thanks, will do it myself with lowered bug springs
Best Regards
kendy
