Old February 25th 2007, 22:02
Rob's Avatar
Rob Rob is offline
Hosed ?
I meed to hook up various air hoses to the intake. Problem is that they are all different diameter.
Any ideas on what to use ? Are there T-fittings out there with different diameters ?
Thanks,
Rob.
Old February 26th 2007, 00:25
Either use some steel tubes and weld them together or get the plastic ends from an old petrol filter, they often have a step to go between 1/4 & 5/16 lines or put a short piece of small hose on the fitting and then slide a bigger piece over it, the small piece acts as spacer.
Old February 27th 2007, 19:15
flat flat is offline
Rob,
If only you knew a man with a lathe....
What size are you looking for?
www.vdubengineering.com
