Old March 4th 2007, 04:41
jrinlv jrinlv is offline
Info on a 944 arm swap
Dose anyone know what size bolt goes in through the alum arm to bolt it to the pan?
I also set every thing in place and it dose not seem like the stock VW spring plates will be the right lenght to work with my late 944 arms. Nothing is bolted into place (note question one) just eyeballing it, thanks for any info JR
Old March 4th 2007, 08:30
Bugnutz's Avatar
Bugnutz Bugnutz is offline
Pivot bolt
JR,
Those bolts are 14x1.5 and 80 mm long.
I just used the stock beetle IRS pivot bolts after swapping the aluminum trailing arm's rubber bushings for some urethane units made for the beetle. These bushings have a larger inner bore than the Porsche units due to the beefy shoulder on the beetle pivot bolt.
With the aluminum trailing arms you will need to use the Porsche spring plates due to differences in the bolt pattern where they attach to the trailing arm.
The rubber bushings are bonded on to the Porsche spring plates. If you cut/grind/burn them off you can use rubber or urethane spring plate grommets and the spring plate retainer for a beetle. I ended up using the inner urethane bushing for a beetle, an aftermarket hard plastic outer bushing for the 944, and cut-down aluminum 944 spring plate retainers.
-Mark.
Old March 4th 2007, 15:43
It will look like this
Old March 4th 2007, 17:28
Thanks for the info, I never had the stock IRS bolts, I bought the pan bear. I thought that the stock spring plates were what you used, back to the internet to find more parts. but thanks again for the info..JR
Old March 4th 2007, 19:04
Bugnutz's Avatar
Those bolts
JR,
Those pivot bolts and the washers that go with them are hard to find but Aircooled.net has new ones.
-Mark.
Old March 4th 2007, 19:06
Cool thanks,
hows the snow?
Old March 4th 2007, 19:34
RCH RCH is offline
wrenchnride do those rotors center on the hubs, or do they just fit over the studs?
Old March 4th 2007, 20:19
Bugnutz,
I'm from Skaneateles NY, and my brother still lives in Auburn, I saw you guys all over the news, Take care and good luck. JR
Old March 4th 2007, 21:52
RCH they just fit over the studs (pretty tight). This is all stock '87 944T parts.
Old March 4th 2007, 22:24
RCH RCH is offline
okay, I was looking at these 87 951 trailing arms I have here, wasnt sure how the rotor fits up. Now to find some rotors and big calipers!
Old June 27th 2007, 13:22
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
Did you have to cut a window in the casting to adjust the spring plates ?or is there enough room for a spanner?
The wisest mind has something yet to learn
Old June 27th 2007, 22:31
Grinding a some off the casting will give enough room behind the spring plate. Some will require more than others. The bolt heads on mine have about 2 or 3mm before hitting casting. I have not driven the car with this set-up yet so, I may need to gring some off if I have any contact. A very thin spanner can fit behind the plate (about 5mm or less thick).
Old June 29th 2007, 19:11
Regarding using the adjusting nuts, I saw a post on here where the most forward bolt heads were welded to the spring plate backs, they only actually lock the spring plate, rearward nut is the adjusting one. I did this on my old 1302 and it worked fine, I also thinned the bolt faces down bit so that I didn't need to grind as much off the chassis.
Old June 20th 2007, 22:47
Originally Posted by Bugnutz View Post
JR, an aftermarket hard plastic outer bushing for the 944 -Mark.
Can you tell me where you bought these. I cant find them on Pelican.
Old June 20th 2007, 23:51
Bugnutz's Avatar
Weltmeister is the word
Steve-
I checked the Pelican website and you are right, the site no longer lists the item for the 944, only the 924. You may wish to call them and inquire. The bushings I got from them have " Weltmeister 017 " cast into them.
As a fallback in the case that they are no longer available, I would suggest that you use aftermarket beetle torsion caps and outer bushings.
-Mark.
