Old March 8th 2007, 13:17
The Pirate's Avatar
Rotary
So who knows what about putting in a rotary?
Pirate VW Services is looking for weber IDF and IDA carbs "to far gone to repair". We are also looking for 74 Super Beetle and later controll arms that are to badley bent to use or repair. PM for details.
Sevice with a yarrhhhh!
Old March 9th 2007, 12:15
do some searches on it. there used to be quite a bit of conversation on it but most seem to be going Suby these days if not staying in the family.
Old April 6th 2007, 13:45
hemitheus hemitheus is offline
I pulled it off with a 12a but it was short lived. I am switching to SOHC ej25
Old April 14th 2007, 01:12
The Pirate's Avatar
Toying with the Idea of a Rennis.
Old April 29th 2007, 13:27
mrjacksonsvws mrjacksonsvws is offline
rotary
the kit from kennedey clutches is 400. and i think you have to run a radiator, which means some water pipping work. if your gonna do it, do the turbo rotary. it would be impressive to see it done.
Old May 31st 2007, 08:14
Dark Wanderer Dark Wanderer is offline
I read about the subject me too and it appears to me that the hardest parts are the wiring and the rebuilding/porting of the motor.
For the wiring, someone told me that if you keep the Stock EFI, you need to keep the original cluster because it wont works without it. Now, I checked and may be a Megasquirt can solve the problem, but again, the problem is to make it running well with the rotary. If you choose to go in carb'd mode, youll have to buy a new intake manifold and a carb setup. I heard many times that the setting of carb with rotaries are PITA so they recommend to go with the Holley Kit that is ready to install and already setted for 6 ports (N/A) and non ported 13B.
The radiator and piping is not hard at all. Only the calibrating of the thermostat is touchy and that's all.
Old August 29th 2007, 16:26
DrFrankenstyle's Avatar
DrFrankenstyle DrFrankenstyle is offline
Check this out: http://www.geocities.com/zenjoe/vw.html
Kustom, pinstriping, DIY culture - www.frankenstyle.se http://www.myspace.com/frankenstylegbg
Old July 16th 2008, 13:03
zenjoe zenjoe is offline
http://frost.bbboy.net/vwengineconversions
Old July 21st 2008, 09:55
vwcossie vwcossie is offline
Superbeetle for Rallycross and Hillclimbing
Mazda 13B - 310 bhp without turbo.
Weber 51.5 IDA
4 pot Wilwoodbrakes front and rear
Bilstein Coilovers front and rear
091 Dog Shift transaxle with LSD
http://wrc.no/index.php?option=com_c...id=27&Itemid=2
Old October 7th 2008, 00:41
bow's Avatar
bow bow is offline
What about a rotary t3 square? anyone with one?
YEAH ITS GOT A HEMI
Old October 7th 2008, 19:59
If your going to go rotary, go the whole way 20B like this bay.
http://uk.youtube.com/watch?v=vhcCCi3UVpU
Old October 8th 2008, 11:59
That's just ridiculous, I have never seen a van come off the ground like that unless it had a V8 in it. Amazing!
Old October 8th 2008, 17:52
It has 650 rwhp and a 6 speed Porsche tranny and its street driven.
