Old April 25th 2007, 08:39
73 Westy 73 Westy is offline
9J Porsche Alloys on Type 2 Camper?
I need help/advice in trying to fit a set of 17" cup 3 alloys on my lowered 1973 bay window camper.
Rears are ET47 9J/17/h2
Front ET52 7.5J/17/h2
I have got 20mm adaptor for the front which I hope will be ok, but it is the rears will be the biggest problem so any ideas would be welcome.
I thought that getting the hubs machined to 130 pcd and fitting a 225/45 tyres would save some width! She is lowered by 1 spline, so
1 What size of spacer will I need to clear the spring plate
2 how do you flare the rear arches if necessary?
3 What length of studs will I need.
Any advice or links would be very welcome.
David
Old April 26th 2007, 04:07
Chris Percival's Avatar
Its notoriously difficult to give you any advice like this. Your best bet is just to offer them up and see how they fit (or not)..
Old May 7th 2007, 07:28
Any one else???
Old May 16th 2007, 22:10
flat flat is offline
Not sure about the bay windows, but I've got 17x9et55's with rear 944 trailing arms under my 65 panel. Very tight, kinda rubs on corners and is super cambered out for tire clearance. But she rolls.....
www.vdubengineering.com
Old May 17th 2007, 07:34
Cheers, I will let you know in 4 weeks how difficult they were to fit!
Cheers
David
Old June 6th 2007, 07:26
pantswagen pantswagen is offline
wanted
70 et 17 inch cup 2's
-can swap for 55et's
