Old July 7th 2007, 13:43
Hoghead Hoghead is offline
915 clutch activation
I have read the archives and if anything am still confused on how to deal with the 915 clutch release problem.
I already have a Suby/915 KEP adapter and 911 clutch.
Hydraulic or mechanical?
Is there a shopping list of parts to do this, or better yet a kit?
Old July 7th 2007, 22:02
If you have "push" type clutch fork you can use the cable on a rear engine set-up. If you have a late model "pull" type 915, you can't use the cable without major mods to exit location of tube out of tunnel, or longer cable. If this is a mid engine set-up you might be able to use the late model with stock cable.
I'm going the hydaulic route with a aircooled.net set-up that replaces the stock cable system. This will prove to be easier than cable for me.
Old July 8th 2007, 13:58
I am leaning to hydraulic as it looks easier but I am still not clear on if this is a simple mod.
I read in the archives somewhere that lever arm ratio needs to be modified to get sufficent stroke, arms flipped, etc.
Is there a definitive method statement on how to hydraulic the 915 clutch?
Old July 9th 2007, 16:31
Nope, and believe me I've looked everywhere. Not even bugat5speed got the conversion covered for a type 4 engine. If you have a suboeroe thingy engine beheind the 915, then yes I believe so as they have experience with that.
Old July 10th 2007, 12:32
Martin Bott tells me that he can do the clutch activation but uses a host of different parts. I have however bought his 915 mounting kit.
As I already have the KEP kit and 911 clutch I would like to use what I have.
If no canned solution, is there a method statement on how to do it using the Saco/Aircooled.net hydraulic kit?
Old July 10th 2007, 21:37
How long before you need to do this? I'm using the aircooled.net set-up (as stated before). I will have pic's and parts needed to do this soon.
Old July 11th 2007, 12:25
I am maybe 2 months away from doing this.
The current need is to buy the parts by the end of July while I am here in Canada and carry them back to Thailand.
Old July 11th 2007, 21:19
I would go ahead and get the conversion kit from aircooled. That takes alot of guess work out of parts searching, and it bolts to stock pedal assy (with access hole cut on passenger side of tunnel). The hard part will be finding a good spot to mount slave cylinder (which is not that hard), and mounting brackets. In two months I better be working on mine...
Old November 1st 2007, 18:55
Hi tomac
I did what Sandeep said and blew them up.
I'm fitting a G50 and I already have a Saab hydraulic slave cylinder and throughout race, but I've been thinking about using the G50 lever and reversing it and using a Beetle through out bearing. I'm using a 200 mm Beetle clutch.
Old November 2nd 2007, 03:29
Hi Steve,
What did you blow up? the 915 ?
Old November 2nd 2007, 08:53
I blew it up alright, all over my computer screen, what a mess, but no cost to fix.
Old November 2nd 2007, 08:59
Especially the pic of the TOB .. it blowed up real good ....
Old November 2nd 2007, 09:24
Next time I 'll try say s/th nasty/funny about watercooling
