Old July 12th 2007, 17:52
vwbao vwbao is offline
rack and pinion conversion
these pictures were taken by our friend JIMP. thanks mate.
Old July 12th 2007, 17:56
Old July 12th 2007, 18:01
Thanks again JIMP!
Old July 12th 2007, 18:53
Great work, you could eat your dinner of that suspension.
You have used a flip kit on your outside tie rods, did you get have any problems? In the past I have seen threads saying that the tie rod would hit the sway bar if you fitted a flip kit to a 2 bolt car. I'm looking into doing this with my other 1303 which has shorter struts and I cant see them hitting at all.
Old July 13th 2007, 04:04
Chris Percival's Avatar
Wow thats lush! Must get my hubs pacified like that..
Old July 13th 2007, 06:26
JIMP JIMP is offline
the car has done a few miles only with the old engine, as i'm preparing the new engine. Had no problems at all (no noise, no scrubing or signs of contact on the the tie rods or the sway bar). The only contact point between them appears when the car is on the air (suspension full extended as appears on the photos) and you come close to full lock at both sides, case that I beleive is a little bit dificult to be realized on the street.
Friendly
Dimitrios
