Old August 20th 2007, 18:19
Veedub Veedub is offline
something different in style
I been doing some thinking of after redoing my bug in basically stock form just to get it on the road (its almost done if crap would stop happening where I gotta buy other things not to do with the VW).
Well I been thinking of 2 things but not sure really.1 idea is a Volksrod theme or I guess its GL but more on the Jap style theme.
For the Volksrod idea I was going to buy a 8" extention for the front, remove fenders,bumper,apron up front, then ste the fenders for front something like a prowler where the fenders turn.The Extention beam lowers the front 2" along with the drop spindles its another 2.5".Then the rear will have the stock look but with wider fenders, and oldschool rims.Oh an paint it solid blue eventually.
Idea 2 comes from a few GL's Ive seen and from the Jap theme.Id leave my bug the colors it is. Then lower the front an rear even. THen get some mid offset wheels that are 7" wide for front an rear an get low pro tires.
I seen a few new VW's with low offset wheels where the are at the lip of the fender.Never seen a bug like this as far as I know.
But will a rim with +20-35et be ok on a bug?
Old August 20th 2007, 18:38
Like this:
Old August 20th 2007, 21:27
Oh no! Don't jump on the "band wagon" and make VW's look like they were from Detriot in the 30's . Don't get me wrong it's a cool look, but IMHO should be left to AMERICAN car's.
For the other part of your post. If you have a really "stiff" suspension, your tires might not rub the fenders AS MUCH during turns from body roll and bumbs in road. I went through this myself.(twelve or so years ago) Your tires WILL rub the fenders if car is lowered, and has wheels that hang past fender lip. Please keep in mind just voicing my opinion. (again)
Old August 20th 2007, 22:52
Stiff suspension? As in what, sway bars...what else?I like the look but how would it look on a bug?Found a site that sales fenders with a flare which i did not know about,how do they look on bugs, ive looked in the members rides but i dont recall any with those fenders.
Old August 21st 2007, 01:07
Bugscandrift Bugscandrift is offline
What site is this that you found them on? Im going to do something similar to mine in the next transformation it goes through which will probably start soon.
If god had meant people to walk, whyd he invent cars?
Old August 21st 2007, 21:02
Yes, sway bars help in body roll. (tires rubbing in corners) But in stiff, I mean larger diameter rear torsion bars. (like 28mm or 29mm) The front can be stiffened up with adjustable beam installed with HD torsion bars, or keep stock bars with adjustable beam, and "pre-load" them. (a little)
I think the flared fenders are avaliable only from europe at present. The CSP site may have them. (can't remember)
Old August 21st 2007, 21:46
http://markvfiberglass.com/index.html has the fenders an there in NV.
Would the tires rub if Im driving normal, this will be my daily driver not a race car.I mean Id understand them rubbing if I took a corner like these guys in hondas an stuff but driving the speed limit an being sensible, will they rub bad?
Old August 22nd 2007, 21:24
Vee, not sure about the quality of markv stuff these days... in the past they were not that good. You will have some rubbing. It just goes with low rides and tires outside the fender lip. I raised my ride height back up a little when my old rims stuck out (just a little) past the fenders. Here's a pic. (over twelve years ago ) I can't find a front or rear shot, but the tires stuck out about half inch. The rear wasn't dropped yet.
