Old October 31st 2007, 03:06
vw62rag vw62rag is offline
944 brakes on a swing axle
hello, i been searching a few forums and i can not find info on this. please help. i have a swing axle trany, long axle, short spline and i want to run 944 brakes if possible. please tell me what exact car and year i need to get these brakes off of and how do i install them, and what kind of machining would be needed. any help would be great.
thanks
Old October 31st 2007, 09:42
Cohibra45's Avatar
Cohibra45 Cohibra45 is offline
Contact Lanner at this website: http://www.vdubengineering.com/
His is the best site and has a ton of information. He is also a great guy to work with.
Just do your research first...
Kelly
Old October 31st 2007, 13:23
great site but i didnt find the info im after. thats why im here, im doing some research. if you have any info on this please let me know, i know for a fact theres a bunch of other people wanting to know this also. if anyone has done this conversion please let me know what it takes to get 944 disc brakes on a long axle short spline swing axle. what year 944 would i need to get the brake parts off? and is there any machining required? any pros and cons to this set up?
thanks
Old October 31st 2007, 17:26
flat flat is offline
You need the rear backing plates from a 924S. They are steel and basically replace the drum backing plate. You re-use the bearing retainer from the VW setup. It is recommened that you drill a hole in the 924S backingplate to give the oil a place to drain (like the drum backingplate has). Then you can use either 924S or early (83-85) 944 rear hubs. If you have short axle, chop 16mm off the front of the Porsche hub. Use all the early 944/924S ebrake parts and add rotor/caliper and you're done!
Or, talk to MBT. They make the backingplate specifically for swingaxle cars.
Old October 31st 2007, 20:06
Cohibra45's Avatar
Thanks Lanner,
Knew you would show up to help!!!
Are you planning on comming to Bug Jam this Nov?
Might see you there...
Cohibra45 (Kelly)
Old November 1st 2007, 00:59
flat/lanner thank you very much for the info. but now im kinda confused, i called a vw shop a few days ago, i told them i found a NA 86 944 and i was taking the rear brakes off, they told me to send them the backing plates and hubs to get some machine work done and they would bolt on...... any idea what they need to machine? im jus trying to find the simplest way to do this without having to find 2 different cars to get brake parts from. oh and who is MTB?
thanks for the help
this is actually for a 65 bus with a 67 bug swing axle trany (long axle. short spline)
Old November 4th 2007, 18:47
Cohibra45 (Kelly)
Maybe, still trying to sneak it in. I'm on the fence....
Old November 2nd 2007, 23:20
any idea? and whos mbt?
Old November 3rd 2007, 12:34
Cohibra45's Avatar
VW62RAG,
Here is the link for MBT.
http://www.mbt-engineering.de/
Take care,
Kelly (Cohibra45)
Old November 18th 2007, 08:16
Are they made from steel?
Old November 19th 2007, 09:26
vdubfund's Avatar
vdubfund vdubfund is offline
MbT steel backing plates
Yeah ,
When I got a hold of Uwe he quoted me 450euro for a refurbished pair sandblasted and electroplated. No mention of new ones. Although it sure looks like they make em.
Looks good! But spendy!
Old November 20th 2007, 23:25
Yeah, the 924 ones are steel and the bearing cap is seperate (2 piece). The 944 ones are aluminum and the bearing cap is part of the backingplate (1 piece).
Old November 20th 2007, 02:07
there has to be another way thats easyer, this shop told me to get the complete set of rear brakes off a 84ish 944 and they would machine them to fit for like 150 bucks. does any one know this method?
Old November 20th 2007, 23:09
Not too sure about this method. You could use a 944 aluminum backing plate, and you will need a spacer to capture the bearing properly, BUT then you only have a oil seal to rely on to prevent oil from leaking. By using the 924 ones, you use the stock beetle bearing caps and you have a oil seal AND slinger to prevent oil leaks. I'll try to see if it's possible to machine a 944 aluminum one for a swingaxle setup....
Old November 21st 2007, 00:35
Thanks Lanner
