986 Monoblocs / Carrera discs to Link pin
Hello to all,
I know I have probably seen this written somewhere, but is anyone running Boxter 986 calipers with early 24mm Carrera front discs on Link Pin spindles.(dropped or standard) If there are pictures out there I would much appreciate seeing them. I am wondering where to place the adapter?? >_< And does anyone know the offset for these calipers, and attachment PCD. Any info/pics/ tech info will be much appreciated. Thanks in advance. Dean And for Lanner if you see this , my chances for finding 924S rear brakes are slim to none right???? Is MBT the way to go?? Thanks for your time and effort as well. |
I'll mock up this weekend if I get a chance with the boxster calipers and boxster rotors using a modified 944 hub. Will let you know how it works out.
As for the 924S parts, I think I have a line on a set. Email me..... Lanner |
I mocked up with a cut down disk as a hub. The rotor and caliper are 1999 Boxster. The diameter if the rotor is too small, so the pads on the caliper interfere with the stock spindle ears before thepad fully covers the rotor. It may be possible to mount the caliper higher above the steering arm.
![]() It may be possible to mount the caliper higher above the steering arm.
