Old November 11th 2007, 14:59
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
T-1 clutch+915?
This winter's project is to install a 915trans into the subaru powered 1302GT.
Since i had the adapter for the original trans and a brand new kep stg3 clutch, i was wondering if the splines of the clutch disc wil fit the 915 input?
If not is it enough to only change the 200mm disc to a custom unit that fit to the 915?
Old November 14th 2007, 13:47
tomac's Avatar
tomac tomac is offline
881861 999768
This one fits to the 915 gearbox. Originally for the 164 Alfa, Lancia etc. 228mm 20 splines. Original Sachs Number. Good luck to get one.
http://shop.snowperformance.de/sachs...799/index.html
Old November 14th 2007, 16:25
1303R's Avatar
1303R 1303R is offline
is it just the friction disc that fits or does the clutch pressure plate fit a 228mm wasserboxer flywheel?
Old November 16th 2007, 14:20
tomac's Avatar
I use that friction disc with a 228mm stage 1 bus pressure plate from KEP!
Old November 21st 2007, 11:29
Cool!
But that is a very high tech sport disk with organic clutch material...and therefore 229 euros!
Would a stock alfa 164 disk have the same measurements?
Old November 21st 2007, 13:29
tomac's Avatar
Yes Wally, the 164 228mm 20 spline disc fit to our 915 tranny. You can look up the number in the sachs catalogue. I use the one on the picture.
Old November 21st 2007, 16:44
Tom,
The picture you showed is quite a different one than in the catalog. Yours has springs. The one in the link looks way different ??
Well, I'll visit my local parts house and check it out; Thanks again!
Old November 23rd 2007, 14:30
tomac's Avatar
Thumbs up
Wally, this is the order number out of the zf-trading catalog. The original 915 spline size comes in @ 20,1x22,3-20N. Did lot's of research in the catalog to find this. Got one on ebay for 20€ and found out that it really fits firmly on the 915 shaft. Believe this will make life easier for those crazy enough to force this gearbox into a beetles arse.
SACHS 1862 256 131 Kupplungsscheibe
* ab Fahrgestellnummer : 6156485
* Kenngröße: 228TPB
* Durchmesser [mm]: 228
* Nabenprofil: 20,1x23,1-20N
* Zähnezahl: 20
Old November 16th 2007, 14:26
if the 915 is the same as the G50, I heard an early style 928 disc should do the job (200mm)
Old November 21st 2007, 11:22
No, different input/spline shaft...
