Old April 11th 2008, 19:29
Rob's Avatar
Rob Rob is offline
clutch advice needed
So my clutch is slipping (so far mostly in 3rd gear).
Motor is a (app 150 hp) Subaru 2.5L.
Should I get a new (hp-type) disk, a heavy duty pressure plate, or the whole kit-n-kaboodle ?
Tips ? Advice ?
Thanks,
Rob.
Old April 11th 2008, 19:53
gonebuggy's Avatar
Rob,
I'd suggest either a stage one Kennedy and a Daiken disk, or a stage 2 and a stock disc.
That's assuming your suby uses a type 1 flywheel? I'm not current on subies!
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old April 11th 2008, 21:26
brujo65 brujo65 is offline
I have kennedy 2500 p/plate with 4 puck on my turbo suby and work fine,
Old April 11th 2008, 22:00
Rob,
The stage 2 with stock disc holds 270 ft/lbs according to the KEP website. I'm running a stage 2 with 6 puck disc .... good for 340 ft/lbs.
I think you're running the stock 4 speed right ?
Old April 13th 2008, 09:22
Rob's Avatar
Rob Rob is offline
Yup, still running the stock 4spd.
I'll probably will stick with that for a while...until it breaks.
Rob.
Originally Posted by Sandeep View Post
Rob,
