Old May 7th 2008, 11:58
mopydereefrm
Blow or Suck???
I have looked into a turbo setup for my 914 motor, and it's no dice!
Unless you custon build it and if i'm going that route why not go with
a hand made intake with a M112 Eaton Supercharger and a sidedraft
carb???
porschedub@live.com
Old May 7th 2008, 15:07
speedy's Avatar
speedy speedy is offline
no real reason not to , but there is a wealth of infomation available to type1 owners about turbo's and lot's of companies cb,staggs etc that can sell you and advise you on what would work best for you , ok the exhaust may have to be custom for type 4 but the rest will be off the shelf ,the eaton will have to have brackets, pulleys , drive belts and other custom parts to make it fit on the engine itself , then there is the small matter of tuning the setup , i am guessing this is such an uncommon setup on an a/c motor that the info on it will be limited .But don't let this put you off a supercharged 914 would be coool and interesting project to undertake , i have seen a couple of lads on the aussie vdubber forums have supercharged there cars so maybe you could get some pointers off them
all the best
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
