Old June 27th 2008, 21:48
QA1 rear coilovers for IRS steel arms
I just ran across this thread.
http://www.924board.org/viewtopic.php?t=25272
Looks promising .... hoping to find a rear coilover to use with relaxed stock springplates and stock steel arms.
Old June 28th 2008, 11:47
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Now find a 'local' solution for the front and we're cooking!
Old June 28th 2008, 14:14
Simon Simon is offline
I'd suggest to get the ones from Gerd Weiser.
They are Bilstein dampers with a main and tender spring from Eibach (ERS), IMHO basically the best shocks and springs you can get (for a reasonable price).
A picture of them:
http://www.keversite.nl/fotoalbum/fotos/55665.jpg
And PeteVW uses them, but he can't turn them down all the way since he is using 944 Aluminium trailing arms
http://www.germanlook.com/Forums/sho...0677#post60677
What do you mean with relaxed springplates?
You want to keep the torsion bars?
I've heard from at least 2 people that they didn't like the combination of torsion bars with a regular spring.
As far as I can remeber this was with KW rear coilovers at 924's.
Old June 28th 2008, 14:48
Thanks.
Yes, I want to keep the torsion bars ... but only to solidify the springplates so they don't deform while driving.
I need to keep the stock steel trailing arms due to my brake system and wheel offset / fender combo.
I don't need to adjust toe in (with 935 style spring plates) ... too much cost for limited functionality. Once the toe is set, you don't need to change it again.
I'd prefer to source things out of North America because the $ to Euro/Pound ratio is not in my favor, even though the products out of Europe are amazing.
Old June 28th 2008, 17:12
typ4boy's Avatar
typ4boy typ4boy is offline
you need one of these...
Old June 29th 2008, 04:40
666bug's Avatar
666bug 666bug is offline
where to buy
Hey Guys,
just looking over this forum and where do I buy the coil over shocks from and how much do they run and the spring plate replacement any info will be fantastic.
thanks guys
Old June 29th 2008, 18:38
moonska moonska is offline
[QUOTE=$aint;66079]I'd suggest to get the ones from Gerd Weiser.
A picture of them:
http://www.germanlook.com/Forums/sho...0677#post60677]
Awesome. Do you have to contact GWD direct to purchase the coilover set? Do they ship worldwide?
Cheers
Old June 30th 2008, 06:35
Cheers
Their webshop doesn't work yet, so you'd have to call or e-mail him.
And he'd be more than happy to ship it anywhere you want
Old June 30th 2008, 07:55
666bug's Avatar
Talking
Hey Guys,
do you have his e-mail address as the site is in German and I realy want the coil overs
thanks
Old July 6th 2008, 21:06
cavemankustumz cavemankustumz is offline
if you want th qa1 set up jegs has them very resonable prices also
where did the uniball spring plate come from
Old July 7th 2008, 04:19
petevw's Avatar
petevw petevw is offline
I made some spacers to clear the arms and properly fasten the shocks. The way it was, the bolt was right up against the bottom bearing mount. Seizing it all up, and interfering with the arm.
I hope to have a motor in it soon. Wonder how it will sit with some weight.
'72 super
'65 bus
'52 split
Old July 7th 2008, 10:32
Thanks for the information.
I'll look at my options and post back the outcome here.
Old July 7th 2008, 12:19
Bug@5speed(US)'s Avatar
Sandeep,
Here is another fellow, who gave me the idea to use the same QA-1 coilovers, not sure you have seen his post on Rennlist.
Very similiar, but gives more detail in some areas, that may not be apparent on the first link. He did not have a good way to attach the top of the coilover.
Here is the link: http://members.rennlist.com/dan10101...vers%20-2-.htm
Enjoy, hope its useful to you.
VR
ALex
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old June 29th 2008, 08:15
The springs used on the GWD coilover can be ordered at Eibach USA and I guess if you call Bilstein USA they can supply you with some coilover dampers.
I guess 935 style springplates are the best solution.
There are cheaper versions available, mainly from sandrail/buggy companies, like here:
http://www.eagleperformance.com/CoilOverKits.html
http://www.dansperformanceparts.com/...gyreararms.htm
Alternatively both Tafel and GWD sell a torsion bar cover with some sort of bearing in it, which allows for removal of the torsion bars.
http://www.keversite.nl/fotoalbum/fotos/57115.jpg
http://www.gwd-weiser.de/aktuell/ang...tabdeckel.html
