Old July 7th 2008, 10:31
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Alternative radiator setup
Hello fellow GL'ers,
In modifying my Ghia with better performance and such without hacking it up, I ran into quite a dilemma with cooling the WBX that I'm using. Most Ghia's that get watercooled have the radiator in the spare tire well which kills it's covert status as well as eats up space.
I was checking out my neighbor's Mini cooper and noticed how compact the radiator was and got the measuring tape out. Voila! The ole' Mini cooper's radiator fits just fine.
Any comments or suggestions on making this work well? I'm going to open the backside of the nostril vents to allow more air into the soon-to-be sealed cavity that the radiator(s) (one on each side if necessary) will reside.
Old July 7th 2008, 14:59
zeroaxe zeroaxe is offline
Hi there,
Forgive me if I ask the obvious... But how are you going to fill up the radiator if the cap is going to be so close to the (top) body? Or are you going to make a trap-door?
Zeroaxe
Old July 7th 2008, 16:09
DORIGTT's Avatar
I will use a remote reservoir and have the local radiator wizards modify the top of the radiator if necessary to put a bleeder valve on each radiators to facilitate getting the air bubbles out if in the end the radiators are the highest point in the cooling system.
I am using the Evans coolant system which is a zero pressure system so I'm not to concerned about the pressure caps and what not.
I was planning to fill the coolant system with this system..
Old July 7th 2008, 21:10
I just had a good read about that system. http://www.evanscooling.com/main21.htm
I'm going to look into it for my new 1303. The benefits are great by the look of things. Thanks mentioning it in your post.
Old July 9th 2008, 15:09
How about one in each fender well in parallel? What is the ID of the inlet/outlets?
Old July 9th 2008, 21:08
DORIGTT's Avatar
My goal is to run them parallel just like Porsche does with their watercooled vehicles. I'll have to measure the inlets and outlets when I get back home Saturday.
The necks aren't that large in diameter which is why I spoke about getting modifications done to them as they're brass which would be easy for any self-respecting radiator shop to work on.
Old July 10th 2008, 20:22
Might I suggest that the diameter of the inlet/outlets is correct for the design of the radiator and shouldn't be altered? If you just split a larger tube into two smaller tubes that are exactly half of the cross sectional area of the larger one, you'll flow just as well. Something like you'd see in an V8 exhaust header, where four small tubes merge into one. As the water flows through the larger tube, when it meets the split, if the lengths of tubing and the radiators are the same, the fluid should flow equally into each radiator, then they can merge back into the large diameter tubing and head back to the engine. Each radiator will have to have a bleed valve on it, but I don't think putting a large inlet/outlet on is the smart thing to do. This is only my opinion and I'm not a hydrodynamics engineer, but it make the most sense to me. If you get a decent airflow over those radiators and use aluminum on the way to the front and back for extra heat loss, I'll bet you you'll be just fine.
Old July 14th 2008, 16:58
Am I right in thinking that you are going to be using a brass/copper radiator with the aluminium block of the WBX? Surely that is going to be an issue corrosion wise? Or does this magical Evans coolant prevent corrosion?
I'm just asking as I've already sized up mini radiators for rear mounting in my soon to be WBX powered beetle and as we know alu mini radiators are going on for £150-200 which is money I don't have to spend
Old July 15th 2008, 05:06
More to that a quote from this website states
Elevated temperatures, which are likely in cooling loops, accelerate galvanic corrosion. A 10°C increase in temperature can approximately double the corrosion rate. Corrosion inhibitors can be added to the cooling water. This retards, but does not eliminate, galvanic corrosion. Corrosion inhibitors bind with the ions in solution to neutralize them. The inhibitors are consumed in this process so they need replacing regularly. Non-aqueous coolants, such as oils, eliminate galvanic corrosion because they do not support ions. However, thermal performance is sacrificed, as the thermal conductivities of heat transfer oils are generally significantly lower than water-based coolants.
To avoid galvanic corrosion, we highly recommend using the same materials, or materials with similar electrical potential, throughout your cooling loop. You should ensure that the plumbing, connectors and other components do not introduce a reactive metal into the system
So you may get away with this Evans coolant completely preventing galvanic corrosion, but I'm no chemist. I know its not 100% on topic, but it serves a point
EDIT: More interesting reading http://www.engineersedge.com/galvanic_capatability.htm
Old July 15th 2008, 08:09
The theory is correct, but I have never seen any damage in engine conversions from this. I've used copper several times myself and had absolutely no ill effects with Alfa or subaru engines....
Old July 15th 2008, 11:18
So Ricola, am I correct in thinking that these engines have either aluminium heads or blocks or both?
Old July 15th 2008, 11:30
Alfa had ally heads on steel block IIRC, subaru all ally...
Maybe it is just a case of using decent coolant...
Old July 15th 2008, 12:19
Thanks for that, just been over the road to see my friend with an autocross mini. He had a spare radiator kicking around which is now in my garage
It fits perfectly under the 50mm wider wings and clears the wheels easily.
Should I now be looking at fabing up some brackets and forgetting the worries about galvanic corrosion?
Just a quick question - what coolant did you use? Is G12+ up to the job?
Old July 15th 2008, 15:36
The only thing I've read of concern is that the fancier coolants tend to be designed for all ally/plastic systems and contain OAT (Organic Acid Technology), apparently this can attack the solder in copper/brass rads so probably best to stear clear of that. I just use bog standard Halfords stuff..
Old July 15th 2008, 21:36
DORIGTT's Avatar
Aww heck!
I'll just use water with a little squirrel guts squeezed in it for flavor
