Old October 19th 2008, 19:27
flat flat is offline
Track Day Pics Oct 19.08
www.vdubengineering.com
Old October 19th 2008, 19:36
And the winner is:
For those who don't know, from the left that is Pete (petevw), Sandeep, Larry(big daddy), Bryan(clkwrk), myself(flat) and Chris(chug a bug).
Thanks to Chris for organizing a great event. I'll bring the bug next time..I swear
Old October 19th 2008, 20:16
CLKWRK's Avatar
CLKWRK CLKWRK is offline
couple more, BTW nice RSR table to set your drink on there Adrian
GL ghia restoration:
Old October 19th 2008, 21:45
petevw's Avatar
petevw petevw is offline
Chris, thanks for a great time. Had a blast.
Above are some pics from my cameraphone, and below a video clip. Everyone make it home OK?
'72 super
'65 bus
'52 split
Old October 19th 2008, 21:58
petevw's Avatar
My last few laps of the day with the 1600:
'72 super
'65 bus
'52 split
Old October 19th 2008, 22:10
My Pics
Thanks for the awesome time Chris. Did Larry make it home OK ?
Youtube videos to come.
Old October 20th 2008, 12:10
C4 Metal Werks C4 Metal Werks is offline
Any info or specs on the oval, bus and orange SB?
Old October 20th 2008, 13:04
Oval is Larry's (Big daddy) and the orange super belongs to Pete (petevw). I'm sure those guys will chime in and fill you in on the specs.
The bus is mine. 65 panel bus. Type 1 IRS conversion with 944 trailing arms and sway bar. 4.75" narrowed beam with 3.5" dropped spindles. 1991 C2 brakes all around. 944 Master cylinder. Boxster 16's. 6's with 205/40 and 7's with 225/50. 4.12 4 speed IRS trans, 1776 T1 motor. It's a pretty tame setup, but then again it's a daily driver (for about 6 months of the year). She keeps up well with traffic on the motorways though...
Cheers,
Old October 20th 2008, 13:41
CLKWRK's Avatar
That white porsche was a twin turbo monster, not a fan of the body kit styling, it was all business.
Old October 21st 2008, 00:33
petevw's Avatar
The orange 1302 is mine.
Been running the 1600 since blowing up the 2332.
-stock 1600 with Dellorto 36 DRLA's
-3.88 solid mounted close ratio trans, Hurst shifter, T2 CV's,
-rear TGFAB kafer brace, KYB gas-a-just shocks all round, CRX front springs on adjust-a-struts, VdubEngineering's upper strut brace
-Ghia front EMPI rear disk brakes, brakes modified to 4x100 and crossdrilled by VdubEngineering
-front and rear bugpack swaybars
-17x7 rims, tires 205/40 and 235/40
-'98 VR6 drivers edition GTI front/rear seats
Any leads on a sport steering wheel?
'72 super
'65 bus
'52 split
Old October 21st 2008, 09:19
Lovely pictures guys!
Sure good to see you all had fun there
Old October 21st 2008, 10:06
CLKWRK's Avatar
sport steering wheel? I have one of these, sort of matches your interior
especial BAG price, sixty buck and its yours
-B-
Old October 21st 2008, 10:10
big daddy's Avatar
big daddy big daddy is offline
Track Day
First of all thanks to Chris ( Mr. Chug A Bug ) for a great event, had a blast. I would do that again in a heart beat. BTW guys nice driving everyone, after a while we all got use to the track and got the lines.
It was a great turn out hopefully we will have a greater turnout for the future and for the next meet which is dated for Nov 23 2008 weather permitting and the 30th for a (rain date).
Hope to see all the rides that was missing or is still hiding in the garages. BRING THEN OUT Maaaaaaaan.....
Big Up ( huge thanks ) to Pete (petevw), Sandeep, Bryan(clkwrk) and Lanner ( Flat ) they tried there best to determine was the problem was. Sanddeep and I was riding together and after 4-5 laps
we really started to have to have some serious fun, then I started to have inconsistent oil pressure and a little ticking noise. We did an extra lap to cool down the motor then exited off the track.
We then immediately stated working on the motor to determine the problem. We checked valves, lifters, rockers and yes after a visual...........we found out that the oil pump bolts was loose. ( NO LOCK TIGHT ) We did a scavenger hunt for nuts and bolts and used what we could find to tighten the oil pump out and to get me home.
Well ya know I should have called a tow truck immediately and I didn't, I tried to take my time to baby it home......????? WHY........IDONO
I reached a for as Burlington and the noise increased so I pulled over and called a.................TOW TRUCK..... .... ( S++T ) what is the wife gonna think now ....a waste of money and time.....LOL
I will keep you posted when I pull the motor out to see what the real problem is.......
C4 Metal Werks is interested in finding out what I am running ehhhhhhhh. ( that is Canadian for IDONO ) this a slang that we Canadians use.
Yes sir! It took 5 years of savings and collecting of parts and asking stupid and annoying questions but I did it.
T4 2600, 78 X 103's, Nickies, ARP's with Ceramic Lifters. excessive head work.
External Oil coolers with thermostat with lines running to the front with fan on the cooler
Case and oil breathers
Full Mallory System
Dellorto 45's with Holley pump ( Still trying to get the right combination for the Main Jets and Air Corrections ) l
3.88 solid mounted Gene Berg mounts with close ratio trans welded gears in a Rhino case, Gene burg shifter, welded in 10 point chromoly roll cage with Kafer cup brace.
VdubEngineering's brakes upgrade to Porsche Turbo Brembo's 17x7 rim Porsche twist , tires 205/40 and 215/50's in the rears.
5 point harness with racing seats.
Dellorto 45's with Holley pump ( Still trying to get the right combination for the Main Jets and Air Corrections ) Anybody out there have a similar combination or has the experience to guide
me into the right direction what are you using for your mains and air correction.
At the present time I am running 45 DEll's, 38 Vents, 210mm mains X 175mm air corrections I have tried many other combinations. As for now the Dell's has to work, cannot afford F.I.
but maybe one day in the future I'll will go that route.
Thanks again to Pete (petevw), Sandeep, Bryan(clkwrk) and Lanner ( Flat )
Ya Monnnnnn...LOL
Big Daddy/ VW EGO
Lets Gooooo
Old October 21st 2008, 10:56
Thanks guys for the info. I think it is the coolest seeing aircooled iron on the track!!!!
My dad bought this 68 Autostick(yep, an autostick) brand new when he worked for VW and auto crossed it for a few years. He still has 3 or 4 trophy's from his wins. VW of NA payed him to build a few more cars like this one to send to other dealers around the USA.
Old October 21st 2008, 16:32
Your sure your fuel lines are big enough, fuel filter is not clogged, tank is vented and your fuel pressure is correct all the way to WOT ?
'I think so' as an answer won't do this time
