Old June 16th 2003, 02:35
Jeza Jeza is offline
944 NA calliper size
Does anyone know what the calliper sizes are for the early 944 NA brakes.
From a previous post I've found that the rear ones are 36mm, can anyone tell me what the front ones are?
Jeremy
1302 RAt "GermanLook"
Old June 16th 2003, 11:58
Hello-
Fronts are 54mm and rears are 36mm.
Take care,
Shad Laws
Old June 17th 2003, 02:06
Thanks Shad
If I'd read your previous post re mc selection for front to rear bias I would have seen that. In fact you even gave the ratio using a stock Beetle mc, so I can now see why people choose to use the 944 one, 23 front and 19 rear.
Is using a 944 mc a fairly straight forward swap? I know it requires fitting studs to the mc, but is the bolt pattern the same as a beetle one, or are new holes needed to be drilled
Jeremy
Old June 17th 2003, 02:17
Hello-
Yup!
The front is actually 23.81mm, which is closer to 24mm...
The standard for calipers is the mm, but for MC's, it is still the inch. MC's are always in increments of 1/16". 19.06mm=3/4" and 23.81mm=15/16". <shrug>
The bolt pattern is the same.
However, the hydraulic port configuration is different, although it uses the same size and thread of fitting. First, there are no ports for brake light senders. Second, the front and rear positioning is reversed: now the forward part of the MC is for the rear brakes and the rearward part is for the front brakes. While the front brake lines can easily be re-routed to the appropriate part of the MC, the rear brake line is too short! I solved the problem simply by putting a tee (same kind as used for the rear brakes on a stock VW) on the rear brake line. Then, I screwed a brake light sender into one of the spots and a short brake line into the other, which goes to the MC. Voila!
The other thing is that IIRC, the rubber grommets for the reservoir are the wrong size for the VW fittings. Of course, my application was a late T3, where everything is different to start with. YMMV on this one, but whatever the case, the modification is simple.
Oh, and the 944 MC is a nice, lightweight aluminum instead of a rusty, heavy iron :-).
Take care,
Shad Laws
Old June 17th 2003, 04:39
Thanks again Shad
The master cylinder sizes I was familar with from your previous explaination... I was just being lazy
As for the decription of the mods for the 944 mc, Fantastic!! Thanks
I do recall what you mentioned re the t piece and brake light fitting, seems like an easy way to lengthen the pipe too.
Cheers
Jeremy
