Old June 29th 2003, 14:06
wacks's Avatar
wacks wacks is offline
boxter wheels fitment!!!!!
need your help guys,
i recently got a set of oem boxster wheels from my friend 17x7 (55 offset) and 17x8.5 (50 offset) i have a ball joint/irs set-up. will the rear wheels still align with the fenders? or do i have to widen my fenders? plz help!!!! have any body installed this on a same set-up as mine?
TNX:
Old June 30th 2003, 10:14
bren's Avatar
bren bren is offline
assuming stock brakes, you'll need a 22mm spacer on the back and you'll have to clearance the rear body mount along with rolling the rear arches.
front you'll need a 10-15mm spacer...
when spacer thicknesses become large and you are changing stud pattern as well, its often best to use an adapter as they combine the two.
Old July 1st 2003, 10:57
wacks's Avatar
will i need to widen the rear fenders? im going to use the empi type 4 to 5 lug adaptor. it's about an inch wide.
Old July 1st 2003, 12:57
Alex's Avatar
Alex Alex is offline
In theory you will not need wider fenders if you keep the stock width with your brakes.....meaning the brakes will not widen the track. You would need a spacer which you can most likely eliminate due to the 5 lug adapter.
Jack up the car.....take the wheel of and stuff in the Boxster wheel. Then you will see how much space you will have to your rear brake or not.
