CAN I USE MY VW TRANS AXLE WITH AN 83 944 TRAILING ARM?
WHAT IS THE ADVANTAGE OF USING THE 944? :silly: WILL THE BACK TIRES STILL BOW OUT? ![]() |
The only advantage to a 944 arm is that it will have a larger stub axle that you can use for beefier T2 CVs. You would just need Thing output flanges to get the inners to match.
But if you have a mild engine the T2 CVs are not needed.
:haveadrin THINKS FOR THE INFO. I HAVE A 1900CC. I SHOULD BE OK FOR A WHILE. THANKS AGIN!!!
Thread Tools | |
Display Modes | |
