Old August 29th 2003, 18:46
kenfyoozed kenfyoozed is offline
home growm dyno
is there such a wa to build a home dyno machne and use gagues of some sort to figure hp an torque. could you possily gt the measurements and then mathmatetically figure the stats?
what would you need?
neil
Old August 29th 2003, 19:52
kdanie kdanie is offline
Do a search using google or other search engine. I remember seeing some info on a homemade dyno that used a hydraulic pump/valves/gages. Heat would change your readings but with carefull notes you could use it for engine development. The numbers would not directly compare to a commercial dyno. All dynos read a little different anyway....
ken
Old August 29th 2003, 22:35
ShApE's Avatar
ShApE ShApE is offline
i once saw a kit wear u jack up the rear end on these special jacks and u take the rear wheels off then u connect this thing to the bolt pattern and hook up the thing to ur computer and it automatically loads a program and u got all ur gauges and stuff on ur screen. I'll look for it, sorry for all the "things"
-= 71 super =-
-= 86 944 turbo =-
-= 84 911 carrera (dad's) =-
-= 76 cadillac seville (me & dad's) =-
-= 2002 toyota sequoia (brother's) =-
-= 99 ford explorer =-
-= 2005 Cayenne S =-
Old August 29th 2003, 22:39
ShApE's Avatar
heres one kinda like it http://www.charm.net/~mchaney/homedyno/dynokit.htm
-= 71 super =-
-= 86 944 turbo =-
Old August 29th 2003, 22:45
ShApE's Avatar
Thumbs up
oh this would be so kool http://www.dynojet.com/a248.shtml
-= 71 super =-
-= 86 944 turbo =-
Old August 29th 2003, 22:47
ShApE's Avatar
or this http://www.dynojet.com/a224.shtml
-= 71 super =-
-= 86 944 turbo =-
Old August 30th 2003, 02:29
petevw's Avatar
petevw petevw is offline
look at this:
http://www.dynapack.com/Productframe.htm
'72 super
'65 bus
'52 split
