Old December 3rd 2003, 23:47
super vw super vw is offline
944 or other brake system?
so what exactly is needed to do a 944 brake upgrade on a 74 super beetle? what parts do i need?
it would cost a good 700-900 for aftermarket disks drilled to the porsche 5/130 bolt pattern so if i can get all the parts for the 944 swap cheaper, than thats the way i will go.
BTW this is for both front and rear.
Thanks!
-Jonathan
Old December 4th 2003, 00:15
63Rag 63Rag is offline
$ whole set. info for adaptation in tech articles
This set up I have may fit your Super alot easier than ball joint Standard Beetle. The 944 front suspension is very similar so it may be a straight foreword swap. I have whole set-up minus: karman ghia (or CB lowered) disk brake spindle . machined braket for spindle to caliper mounting. interferance bushing so front porshe hub can mount on to spindle. and machining of porsche hub.
Check out SALE section;
http://www.germanlook.com/Forums/sho...?threadid=3328
I think $250.00 for set puls shipping may be reasonable.
Good Luck.
Ralph
