Old December 8th 2003, 15:51
boygenius's Avatar
Question Removing paint.....
Is there an easier way to remove paint from my cars chassis. I want to strip it to bare metal so I can coat it with POR-15. I have tried a wire wheel, a 3-M fiber disc, POR-15 paint stripper, regular paint stripper, and an elctric sander. I am having a really hard time getting the paint off of my new floorpans. Help. I don't care if the solution is toxic or dangerous, as long as it works...
Old December 8th 2003, 17:18
Racelook's Avatar
Racelook Racelook is offline
You can let your chassis dipped...
I don't know what the use as removing liquid.. but is strips hole your car and removes al rust what was in every corner..
Greetings.. Wiebrand
B-Extreme B-Tuning.....
Old December 8th 2003, 17:24
Shadowbug's Avatar
sand blasting works just lovely on pans.
I personally like 2 part epoxy paint on bare metal, tough as anything and looks sharp. Did a friends pan with 2 part epoxy primer then 2 part gloss black. and because its a chemical cure rather than air cure, you can lay it on thick and its dry within an Hour.
a few pics of my project
Old December 8th 2003, 17:39
Yeah you might wanna try getting it blasted, I preffer sand when you deal with rust and soda blasting when all you need to do is get the paint off, it doesn't damage anything, good luck man.
If you don't want to do that, Ryobi makes great angle grinders, make sure that the wheel is brass-coated steel wire and it should do the trick. It's time consuming but it works great and takes off anything. I used one on my dads Harley to strip all the paint and bondo off, and it took everything off....
Hope that helps man
John
VolkSport Kfer Gruppe
www.VolkSport.net
Old December 8th 2003, 18:20
boygenius's Avatar
I figured it out. It was too cold yesterday for the stripper to work. It was like 45 degrees and today it is 70 degrees. The paint now comes off with a garden hose. Although I do have a little headache now from the stripper.:silly:
Old December 8th 2003, 18:25
glad to hear about the stripper problem getting resolved, or should I say disolved, sorry bout the head ache, I hate the smell of paint stripper too.!
John
www.VolkSport.net
