Old December 15th 2003, 02:19
Alex's Avatar
Alex Alex is offline
This should help.
Old December 15th 2003, 05:35
hot66's Avatar
hot66 hot66 is offline
thats how I've mounted mine, but my handbrake almost touches the shifter (10mm clearance between shifter body & handbrake button) (1303 pan)
What pan are you running or have you shortened the handbrake?
project in progress
Old December 15th 2003, 06:02
Alex's Avatar
67 swing axle converted to IRS. E-brake handle is not modified.
I have seen it being a tight fit on a Super.
Mine is okay. Look at it this way.....you do not normally use the e-brake while driving.
Old December 15th 2003, 06:36
hot66's Avatar
depends how you drive
project in progress
Old December 15th 2003, 22:11
danielzink's Avatar
danielzink danielzink is offline
Well.........I've email Oliver twice now. No response...does anyone know if there are any other distributors for the shifter ?
Thanks, Dan
65 notch 2300cc type4
www.danielzink.com
Old December 15th 2003, 22:13
Alex's Avatar
Gerd Weiser is one. www.gwd-weiser.de
All the German Tuners sell it I believe.
Old December 16th 2003, 22:22
hot66: I know what you mean, tight, hard,sharp corners are easily taken with the e-brake, just a little harder to double-clutch when you do this, better to heal and toe it. If you know what I mean
John
VolkSport Kfer Gruppe
www.VolkSport.net
Old December 17th 2003, 21:20
boygenius's Avatar
I always liked to bring the rear of the car around with the throttle and not the brakes. 1969 beetle with worn out suspension and plugged tires in a four wheel drift, now thats what I call fun.
Old December 18th 2003, 00:50
Eurolook71 Eurolook71 is offline
t-shifters are for drag racers, IMO. A nice round ball seems more GL to me. For shifters, stock with a short throw kit is great. If you know your car, slipping into the wrong gear shouldnt be a problem.
Gotta admit, that shifter Alex has there is wicked. Would hurt my feelings to trade in stock for that!
=EuroLook71=
71' Super Beetle
1.6L DP - Kadrons, stock heads P&P by me
Old December 18th 2003, 10:52
The stock shifter is often thought of as inferior, and attention is given to the shift rod bushing, but often the problem is just an old sloppy tranny. A new tranny can be set up nice and tight which translates into a shifter, even a stock one, that has no slop.
Old December 18th 2003, 23:03
true, but you gotta admit, that it would be easier to shift with a stick like Alex's. Even if your tranny any everything else is pristeen and right opn the money, it would be easier to race and drive with simulated sequential shifter....IMHO It just depends on the person!
John
www.VolkSport.net
Old December 18th 2003, 23:15
boygenius's Avatar
I bought a used T-handle short throw shifter for $15 and never missed a shift, even with a bent shift rod. I've always wondered if it was an original EMPI shifter since it is about 25 or 30 years old.
