Old February 28th 2004, 15:13
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Alex's Type IV engine...
So, if someone was to buy Alex's engine and build it up what changes would you advise? Turbo? Swain Tech ceramic coating on piston crowns and heads/valves, exhaust system and turbo? It will be going in a 1200 pound (or less) Meyers Manx so engine size is pretty open. And yes I know wings would help... It will be a street/autocross car.
Jake I would truely appreciate your opinion.
Thanks,
Randy
Old March 10th 2004, 16:39
cnavarro's Avatar
cnavarro cnavarro is offline
Well Alex's set of 102mm Nickies most certainly could hold up to the boost, but the c/r was set up for N/A, so some shimming will need to be done to reduce the c/r, but hopefully not at the expense of running a tight deck.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old March 11th 2004, 23:49
SuperRSi's Avatar
Charles,
My end of the deal fell apart so I will not get the entire engine. This means I will be calling you in a few weeks about some P&C's.
Thanks,
Randy
Old March 12th 2004, 08:25
cnavarro's Avatar
Sounds good. I'll work out a deal on a set of 103s for you. Pistons cost me less in that configuration. BTW,i'm down to one set of p/cs out of this next run that are unsold, fyi.
Charles Navarro
LN Engineering
