Old January 4th 2005, 14:53
Racelook's Avatar
Racelook Racelook is offline
Originally Posted by justdubbin
Wow that looks great...
Thats some very impressive steelwork & welding for someone so young
That going to be an awesome GL car when you've finished.
Thnxxx
p.s. Most of the welding from the tubes is done by my 17 year old brother...
Grt Wiebrand..
p.s. thnx for the nice comands!!
B-Extreme B-Tuning.....
Old January 4th 2005, 15:15
justdubbin's Avatar
Originally Posted by Racelook
If you pay my trip, steel and a lot of money I will hahaha..
If I had that much money my bus would be finished now
Rob.
Old January 4th 2005, 19:12
Angelo Amato's Avatar
Great Work !
I want to make a rear hoop for my fastback.
You get good results using that type of bender by the looks of things - surely must be good enough for a one off ? :agree:
Type 3 Fastback
Old January 5th 2005, 12:38
kdanie kdanie is offline
Nice work, good fit of the bars to the body. I need a hydraulic tubing bender like that, I already have the welder....
ken
Old January 16th 2005, 07:10
Dasdubber's Avatar
Fantastic work, it is looking excellent thus far, can't wait to see it progress!
Old January 24th 2005, 19:17
Racelook's Avatar
So another update...
This afternoon I finally was free form school so I could work on my car.. Lot's of the prepwork was done on sundayafternoon (in an cold garage -> the heater was dead)
At first we welded up the right box on the rear wheelarce.
At the other side an backplate was welded in.. An yet another piece of foam was burned out :twisted:
http://www.keversite.nl/fotoalbum/fo...2005221714.jpg
The sideplate of this boxe is also made right and will be welded in tomorrow
Also we welded the tubes from a-to b-pilar on there "footplates"
Also the left side is welded on the "footplates"
http://www.keversite.nl/fotoalbum/fo...2005223036.jpg
And the last thing that we did today was beginning at the making of our strutbrace. On every plate will be attached 3 tubes (if everything goes as planned)
I hope ya like it!!
Wiebrand
Old January 24th 2005, 19:38
MattKab's Avatar
MattKab MattKab is offline
'Makes me want to cage my Kab...
Your making it look so easy!
:agree:
Matt
Old January 24th 2005, 19:43
Racelook's Avatar
Yeah look easy...but I can tell it's not The real making is quite simple... But the thinking of where you want to put that, what is the point when I make that there, which form, how should I make that.. that cost a lot of thinking and time..
But hell yeah.. in dutch: Met gezond verstand kom je een heel eind! (With healthy thinking you come an hole end)
GRt Wiebrand
Old January 31st 2005, 13:33
Racelook's Avatar
Hey mates.. It's been an long time but here's an other update.
At first we had drawn where the tubes will go trough the "dashboardmetal" and cut that out.
At this point I was lucky that I already had removed the "freshairbox" that is hanging in the boot under the frontwindow because otherwise the cage couldn't be coupled to the frontstruts.
I also was obliged to remove the trunkhangs (do you call them so??). Tja The cage didn't fitted otherwise so hell yeah than the hangs has to get lost :wink:
Some pic of the tube that goes from the cage to the frontstruts seeing from the trunk
http://www.keversite.nl/fotoalbum/fo...2005005022.jpg
Pic of the interiorside
Detailpic
http://www.keversite.nl/fotoalbum/fo...2005005213.jpg
Two brackets made and welded on the plates to make the strutbrace.
Old January 31st 2005, 13:34
Racelook's Avatar
And here the totallpic of it..
And off course everything under supervision of my brother
Greetings Wiebrand
p.s. Can that stupid *(&#^@ 30 seconds, and too much pics added in one post message not kicked on it's @$$???
Old February 1st 2005, 16:14
starmember's Avatar
nice work what kind of tubing are u using.
90 in to te corner.
Old February 1st 2005, 17:58
Racelook's Avatar
I use 42,4mm diameter tube with an thickness of 3,25mm. The tubes are "offglowed" after the bending/mold proces in the fabric so that there are no stressreflexes left in the tube. (I hope that you understand what I'm telling in my bad english)
WIebrand
Old February 2nd 2005, 14:30
starmember's Avatar
ik ook maar ik verstond het prima.
90 in to te corner.
Old February 2nd 2005, 15:27
justdubbin's Avatar
Is it the angle that this picture is taken
because it looks as though you might not be able to connect the fuel filler?
I hope I'm wrong
Rob.
Old February 2nd 2005, 16:46
ANypne who can fab. a rollcage like this can fab. a new filler neck :agree:
