Old January 10th 2005, 03:36
rip's Avatar
rip rip is offline
Pedal Assemblies
was wondering if many have used wilwood or tilton pedal assemblies in there bugs?
links?
I don't even know how much $$$ they really run, but curious if this should be an option of mine.
thanks
Rip
Old January 10th 2005, 15:57
Doogie S's Avatar
Doogie S Doogie S is offline
I think the pedals just bolt thru the pan to the floor. You can use a plate that allows some movement of the pedals for different height drivers, but the biggest concern I would have is how much the pedals are moved forward (towards the drivers seat).
The set-up I was looking at is mostly used in sand rails with a hydraulic brake and clutch slave cylinder built in. In a sand rail, the mounting wouldn't be an problem as everything is on the open, but in a Bug (or Ghia) that isn't the easy as you need to get the pedals in the right location to get the accelerator cable thru the tunnel.
This is why I just decided to go with the standard pedal assembly and use the cast aluminum pedal pads that Ken used in his bug.
Just some of my thoughts on the idea, but I would like to hear from someone who actually did it.
Cheers,
Doug
PS: JEG's has Wilwood pedal assemblies for under $200 US
Old January 10th 2005, 18:35
rip's Avatar
rip rip is offline
see I was looking somthing more along the lines of this
http://www.wilwood.com/Products/005-...mtmc/index.asp
I believe tilton makes one similar. The nice thing here they have it in the smaller ratio, 5.1:1. Plus if you build a small cage inside the car at your feet you can squeeze everything in and not really lose foot room.
sort of like this
Old January 11th 2005, 05:22
rip's Avatar
rip rip is offline
looks like the biggest problem would be the steering column. I think its in the way. Don't know if theres enough hieght. But if you can fit the normal 6.2?:1 pedal ratio in there the smaller one, plus the master should be too bad.
Anyone?
I've been searching through the old mag. but it seems like more people used the CNC styled pedals. and they look a bit smaller.
rip
Old January 11th 2005, 05:29
rip's Avatar
rip rip is offline
have you guys seen this? CNC web site
http://cncbrakes.com/cncbrakes.com-a...228&subseries=
Old January 11th 2005, 18:03
rip's Avatar
rip rip is offline
just in case somone else is also interested in this stuff, theres some good pics
http://community.webshots.com/album/39423047UQlzuf
http://community.webshots.com/album/68341357kTvPqD
rip
Old January 12th 2005, 12:15
oasis's Avatar
oasis oasis is offline
Pardon my ignorance, but what are the advantages to any of these pedal assemblies? Or, what is wrong with the stock pedal assemblies?
Old January 12th 2005, 17:39
rip's Avatar
rip rip is offline
well nothing
it's really my own "doing it right" thing. Figured with the new brakes I'm going to have I need a new master cylinder; and because of the combination of brakes I hope to use, and a lack of MC that will work well, I figured the dual MC brake thing would work. That way I can also control the brake bias.
See I been re-reading the posts inwhich people have gone through the trouble of putting porsche brakes on. And then having the head ache to figure out which MC to use. Then to shell out the $$$ amounts of cash for a porsche part, well maybe not this time but the next time around, if they found one.
I wanted an alternative that wasn't porsche, that was as good but le$$. Learning that wilwood and tilton both make brake pedal assemblies I've been toying with the idea of using one of these.
Now you may be thinking what brake combination could this guy want that will cause such a weird thought. Well I will be using 4 pot Rx7 front calipers and probably CB or even So Cals rear brakes. And because of the large difference between caliper sizes, volume needed, and the control of bias; I thought the break idea was a good thing. In the end I hope for a cheaper way to get brakes just as good as a porsche.
Rip
Old January 13th 2005, 08:21
bigwindow bigwindow is offline
I have also considered this type of brake/pedal solution..
But is the MC big enough??
I think Tilton's MC is 21 or 22mm.. that is OK, but not BIG...
I love the apperance of the Tilton's and would by them, if i'm going for it..
1963 Germanlooker projekt
1969 T-1 daily driver
Old January 13th 2005, 08:29
oasis's Avatar
Interesting answer. Thanks.
I, too, shied away from Porsche brakes with all of the talk on master cylinders and proportioning valves. I ordered and should be receiving in the next few days KG-based brakes drilled in a 5x100 pattern for all four corners. I figured in a light car like my 1302, it'll be plenty of stopping power -- although some people profess the too-much-is-never-enough theory -- and without any other issues attached.
Of course, we'll see once everything is installed if my reasoning in reasonable.
Old January 13th 2005, 08:39
I have 993TT discs and calipers on my car, with 944MC, but it's still a project car so I have no experience with it yet...
Old January 13th 2005, 18:35
rip's Avatar
rip rip is offline
Yea, I'd like to take my car out to the tracks everyonce awhile, not to really compete, but more to drive and have some fun. I'll have a 120Hp type IV motoro done soon and need to stop, plus been looking at rotarys for awhile. And who knows what the future holds.
The main problem I saw with the stockish disc brakes is that they were still single planed rotors, no vents. They will still stop you, but in a daily driving situtation inwhich most new car on the road can out stop you I figured bigger is always better when it comes to brakes.
Old January 13th 2005, 18:40
rip's Avatar
rip rip is offline
Also can someone tell me why you would have a larger rear mc than the front.
I've been on a few Rx7 forums to see what mc they use for manual brakes. And some have said that they use a
3/4" front mc
1" rear mc
I don't get it. Wouldn't the front brake use more fulid thus need a larger mc?
thanks
rip
Old January 14th 2005, 14:14
oasis's Avatar
I could have had the brakes cross-drilled and vented. I was told the advantage of that was protection from overheating. Otherwise, more surface area of the brakes not being cross-drilled and vented would offer more braking power in an emergency situation.
My situation will not include so much braking whereas I worry about fade. My mechanic even suggested leaving the rear brakes as drums. (I chose to veto him on that one.)
I do not believe my set-up will have me out-braked by most cars on the road. If you ar right about that, I will be disappointed. I know one thing: when they're installed, I'm going to test them against my 2002 Cabrio, my wife's 2002 Golf, and my dad's 2002 Passat. If my '71 1302 finishes anything less than second place in this four-car test, I will concede you are right with your daily-driving assertion. (I won't test it against my 1993 EuroVan because {a} I'll soon be selling the EuroVan, and {b} it stops better than the heavy Westfalia already.)
Logic tells me my 1302 should darn well match or beat the above competition given the ratio of brake size compared with the ratio of vehicle weights. I realize this logic is dependent on there being a linear relationship between the two factors, and is excluding any other factors.
I'm quite sure there is a geometric relationship between brake size and vehicle weight when it comes to stopping power. There has to be. Otherwise, some figure like 20-inch brakes (try to imagine that one) would theoretically stop the car instantaneously. And if "twenty" was the magic number for zero feet at 60 mph, then 21-inch brakes would produce a negative number.
So being secure a geometric relationship exists, there must be a point of diminishing returns as one deals with the asymptotic tail (for those playing along with a graphing calculator). There may be even a point of negative returns -- where bigger brakes given an otherwise constant situation actually produces worse results. (The provisions and weight of a 20-inch braking system, if even possible, may be just that.)
It is my belief -- and 98% of this belief came from the culling of many opinions here, at other sites and elsewhere plus 2% of my residual knowledge from being an econ/math major -- I should be fine in my daily driving application using TopLine's Karmann Ghia-based brakes and a set of four 205/55-16 tires underneath my 1302.
I'll let everyone know. It would be curious to see what others would produce with their Porsche set-ups even though it would be carried out on a different road surface at different temperatures ... blah, blah, blah.
Now if I drove my 1302 a lot or planned on experiencing track time, maybe going the extra expense and experimentation to find the supreme set-up would be worth it. I may in fact do that on my next Super (a 1303 most likely).
More later ...
