Old January 15th 2005, 05:12
jimby jimby is offline
Schleicher Camshafts?
Schleicher camshafts seem to be very popular in type 4 engines. im not familiar with them. ive looked for a website that details their specifications and can't. does anyone have details on schleicher camshafts and know where we can buy them from?
Old January 15th 2005, 05:39
Wesayso's Avatar
Wesayso Wesayso is offline
Schleicher 316:
246 deg at 1.27mm, 212 at 2.54mm, 076 at 7.62mm, lobe lift 8.50mm, lobe separation 105 deg.
Schleicher 324:
262 deg at 1.27mm, 222 at 2.54mm, 109 at 7.62mm, lobe lift 9.40mm, lobe separation 106 deg.
That should help.
They are available at Klaus Kaefertuning and probably other German tuners...
Old January 15th 2005, 18:02
Hi, Ahnendorp sells those as well.
I like them as well, also because they come with a new cam gear already attached in the original VW manor, so you have less clearance problems with aftermarket, type 1 style, oil pumps
Walter
Old January 16th 2005, 05:07
dirk.Gysbrechts's Avatar
dirk.Gysbrechts dirk.Gysbrechts is offline
Camshaft
you can find technical info about the camshafts here...
http://www.eckstein-kuebel.de/NWT1.htm.
