Old January 14th 2005, 21:22
Bullyboy Bullyboy is offline
58' panel with phone dials?
I am trying to find out which offset would be correct for a set of phone dials on a 60' panel. I was thinking of 15x6 on all 4 corners unless someone has some better ideas. We will be running disc brakes on the front and redrilled drums on the rear IRS conversion.
Old January 14th 2005, 21:29
vujade's Avatar
vujade vujade is offline
either 6's or 7's with an et52.3 not the 23.3 offset....
WinterJam 2010
Old January 14th 2005, 23:43
great.....that seem to make the most sense with the offset of the stock wheels.
thanks
Old January 15th 2005, 18:34
Pillow's Avatar
Pillow Pillow is offline
You can go 7's if you really push it in the rear. Actually easier if you do 16"s to shoehorn the tire in the rear wheel arch. The front needs a few dinky things done to fit as well for 15x7s (again not a problem if you run 16s).
FWIW I am running Phones 15x7 all around on my '66 Wesyi with IRS and early 944 discs. I like it a lot!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old January 16th 2005, 10:39
Which irs kit did you go with on the 66'? Good- bad? I'll see what I can find for wheels now that I have an idea of what I need.
Thanks guys
Old January 17th 2005, 01:49
Pillow's Avatar
I used the Bus Boys kit mostly (some Old Speed parts as well). The Bus Boys kit seems expensive at first but is the only real bolt on solution that I know of.
Adrian Pillow
