Old January 18th 2005, 08:57
Bad bug's Avatar
Bad bug Bad bug is offline
2.0l type4
What is the size of the valves in a 2.0l square port bus head. These heads are AMC heads.
Old January 18th 2005, 10:53
vujade's Avatar
vujade vujade is offline
I believe it is 37 x 33 in the bus 2.0 heads, not sure if the vanagon 2.0's are the same or not
WinterJam 2010
Old January 18th 2005, 11:12
The AMC heads have 41X34mm valves. I found that on aircooled.net hope that helps.
Old January 19th 2005, 08:31
Bad bug's Avatar
2.0l t4
Thanks for the info. What would the power be like with 44 x 38 valves in the head and a mild cam on a stock bore stroke engine.
Old January 19th 2005, 09:00
vujade's Avatar
Stock 2.0 914s had 95 to 100 hp depending on the piston they used.
And that was with 42 x 36 valves and about 8:1 compression.
So if you bumped the compression up to 9:1, went with some bigger valves, a mild cam, some port work on the heads, maybe get 120 to 125 hp.
WinterJam 2010
Old January 20th 2005, 09:05
Bad bug's Avatar
2.0l t4
The pistons that are in the engine are the dished one's. I don't know if this is high compression or low compression.
Old January 20th 2005, 09:58
vujade's Avatar
dished pistons are the low compression bus pistons.
the 914 pistons were either flat or domed.
flat had 8:1 compression
and
domed had 8.5:1 compression
WinterJam 2010
Old January 22nd 2005, 18:49
Mark the canuck Mark the canuck is offline
and
A little wrong...I think the ratios are right, but 914 pistons are flat top (Euro) and small dish (USA/Canada) BTW way smaller dish than bus pistons.
