Old November 18th 2002, 11:32
Spanish Flea Spanish Flea is offline
1500cc to 1600cc=- Talkn' Carbs here
I just rebuild my 1500 to a 1600 single port. Do I need up upgrade my Carb?
I'm using a 30Pict-1 on there now, and with a little lookie the 1600 uses is the same carb (30Pict-3) with a smaller jet.
As it is now. I get hesatation with no power in 3rd and 4th.
So my question is should I cange my carb, or could I just get a smaller jet and still use the carb I have.
Spanish Flea
Old November 18th 2002, 14:32
TitoRay
If you have hesitation or want power I suggest upgrading to dual carbs.
Old November 18th 2002, 14:57
I don't want to do this. I want the engine to look as stock as possible. So changes would have to be slight. And it not that I'm looking for "Power", when I shift into 3rd It acts like the engine is dying. no foward power, just lags.
Old November 18th 2002, 19:57
TitoRay
Oh, ok. I am not sure about the carb jets and such. Someone will surely help though.
Old November 19th 2002, 14:13
Pillow's Avatar
Pillow Pillow is offline
I like the 30PICT-1 much better than the later -3.
Make sure the carb is clean and rebuilt well. Check for vacuum leaks.
What dizzy are you running? The stock vacuum can could be shot? Overall I like the stock single advance dizzy better than anything else on a SP 1600. Great drivability.
Good Luck,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old November 19th 2002, 15:18
I rebuilt it myself not to long ago. It could use another cleaning. I ran some bad gas before the rebuild of the block plus the tank had a lot of crud in it to.
Good Luck,
Me too. It's a simpeler carb
I'm running a 009.
Spanish Flea
Old November 19th 2002, 23:56
Pillow's Avatar
The secret is getting the passages blown out with compressed air. There is a lot of mystery garbage hidding in those passages
Later,
Adrian Pillow
Old November 22nd 2002, 11:55
Well I rebuilt my carb last night and she is purrrrring like a kitten again. There was about 4mm of rust dust in the bottom of the carb bowl.
Thanks everybody,
Spanish Flea
