Old July 17th 2005, 21:50
rustbucket's Avatar
That chassis looks totally sick. It'll be a blast on the track when it's done.
And I'm taking notes. I'd like to do a super next time around if I can't find a good T3.
It's YELLOW
Rolling on a daily basis.
Old July 17th 2005, 22:23
yetibone's Avatar
yetibone yetibone is offline
Thanks!
I've always thought that GL Type IIIs' are to GL Supers', what a Mercedes Benz E55 is to a Porsche 911.
I've never owned a Type III, but I still think Supers are where it's at! :agree:
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 17th 2005, 23:06
rustbucket's Avatar
I've always wanted a Squareback. Heck, I might even do a Bus. But surveying the aftermarket, I'll probably end up with a Super. T2's & T3's are just so much more expensive in every way. And down here, they're so hard to find in good shape. Plus I get envious reading all of the Super threads!
It's YELLOW
Old July 18th 2005, 12:54
vujade's Avatar
vujade vujade is offline
Thats good way of putting it Yeti... I usually tell people that I consider
GL T3's more like a BMW M3 vs Supers being like 911's.
WinterJam 2010
Old July 18th 2005, 18:09
yetibone's Avatar
Exactly. There's Soprt touring cars, and then there's sports cars.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 18th 2005, 19:11
Superbug Scott Superbug Scott is offline
Thanks BG. The holy pedals were kind of an afterthought, but I'm glad I did the drillin' :agree:
You drilled the pedals yourself!!?! They look great!
I want a new cluster too.
Old July 18th 2005, 19:18
yetibone's Avatar
Couple of pictures of the Kerscher dash. Not done with it yet. Gotta get a 911 clock, and paint it, or gel-coat it.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 19th 2005, 06:22
starmember's Avatar
Sweet dash
90 in to te corner.
Old July 19th 2005, 11:37
Racelook's Avatar
Racelook Racelook is offline
Same dash that I have, only I have to modify it even more..
Looks nice!!
B-Extreme B-Tuning.....
Old August 5th 2005, 22:20
yellow73's Avatar
yellow73 yellow73 is offline
That dash looks great Joe!!!
73 Type 1 - 2270 Type IV
64 Type 34 - 1500 Type III
Old September 11th 2005, 21:34
yetibone's Avatar
I started doing actual bodywork today. Made a patch piece out of a section I got from jhelgesen. I cut the rusted section out months ago to make it easier to remove the wiring harness. I left the fold on the underside of the drip rail intact, so the patch will be inside the fold. I haven't stitched it into place yet 'cause I have to make some patches for the inside, lower rear window corners.
The other side will be easier 'cause I don't have to cut the outer window corners, just the inside.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old September 12th 2005, 13:06
Mikey's Avatar
Mikey Mikey is offline
Most 1303 supers are terible about rust in that area. I've seen a few that were a lot worse than that. The patch looks good to me.
Mike
'04 R32 Tornado Red
Old September 12th 2005, 18:09
yetibone's Avatar
I can only assume the reason is because of a different type of foam. The patch came from a section of an earlier model, and the foam was pliable.
My '73 has foam that's kinda like 'Great Stuff'. It's not flexible.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old September 12th 2005, 18:43
Racelook's Avatar
Yetibone, why didn't you removed or blasted the rusted (inner) piece at that corner?? (it looks rusty to me)Sorry I was reading too quicky
Keep up the good work. ...
It's an place were almost every 1303 is damn rusty. (I had to cut out hole the corner (inner and outer piece) en welded in an doner to make it nice)
Old September 12th 2005, 18:54
yetibone's Avatar
Yes, I saw that... I figured your car had much more extensive damage than mine as it looked like you had replaced the whole base of the pillar, not just sections of it like I'm doing.
BTW, excellent bodywork Wiebrand. :agree:
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
