Go Back   GermanLook Forums > General > Members Rides
Old January 1st 1970, 00:00
s1fter s1fter is offline
Questions about s1fters ride
s1fter
"Should make a good project and say goodbye to your bank balance"
www.themetricnut.co.nz
Old March 23rd 2005, 17:55
TOW74 TOW74 is offline
Master cylinder
Hello s1fter,
My name is Charles. I wanted to know what master cylinder are you using for the 944 brakes, and how does it feel when you are stopping? The reason why I am asking is because I am using the 944 brakes on my 1303 cabrio. Thanks, Charles PEACE!
Old March 23rd 2005, 19:19
Jeza Jeza is offline
Charles
Have a read here
http://www.germanlook.com/Forums/showthread.php?t=4595
There was a large discussion on the early single pot 944 brakes vs the later 4pots with respect to the master cylinder.
The general verdict was that the single pots require the split bore (23 / 19) 944 master cylinder and the 4 pots are ok with the bug 19mm one.
There are always those that will be different - and s1fter has a variation on this- I'll let him explain it.
Cheers
Jeremy
1302 RAt "GermanLook"
Old March 24th 2005, 01:01
Hi,
unfortunelatly I have not got my car running yet, (Distractions!!!! Type 2 single cab!!).
I have installed a Suzuki Barina master cylinder as it fitted my aps best, but looking at it, it would not fit in the standard hole, without a lot of mods.
The bore size works out to be about 20mm (It's imperial!) and I will be going from there, as I may get it re: sleeved larger or smaller after I have tested it.
Hope this helps
s1fter
s1fter
