Old October 31st 2005, 07:30
dgluyas's Avatar
dgluyas dgluyas is offline
1303 Lowering problem/control arms
Have a late 75 1303.
Installed lowered struts.
Now lower control arms will bottom out on rack and pinion mount if really pressed hard.
Also, tie rods from rack and pinion now dont have enough adjustment.
Sway bar seems to be twisting lower contrtol arms too.
Anyone been through theese issues ?
Thanks in advance
David
"Goliath"
Big motor-Big brakes-Big wheels-Big FUN !!!!
Old November 1st 2005, 11:48
Turbo Haraune's Avatar
Turbo Haraune Turbo Haraune is offline
I wil recomend that you install a lowering swaybar too. to stop the twist.
They are made with a different angle.
Check out my project pic`s!
http://www.v-dubs.no/haraune
Old November 1st 2005, 22:08
Have you got the swaybar up the correct way, silly question but many people get it wrong. You can also fit some blocks under the front sway bar mount to lower the front of the bar, my alignment guy said that it would also help with anti dive when I did it.
