Old January 13th 2006, 07:12
MX67 MX67 is offline
928 Limited Slip Diff in Bug gearbox? Possible?
Just saw LSD from 928 cheap in yellow pages, anyone knows is it possible to put it in the beetle gearbox?
Nobody talks about 928. Is that model so different comparing to 944?
Thank's!
1967 Bug
Old January 13th 2006, 08:32
brujo65 brujo65 is offline
Yes, is very different is a mercedes gear box
Old January 14th 2006, 00:28
R2.0 R2.0 is offline
I thought the auto was a Mercedes product but the manual was 915 based.
Old January 16th 2006, 05:44
Automatic is Mercedes product, but manual is Porsche made.
So, do you know is it possible to use 928 limited slip diff in a Bug's gearbox?
Do you have some techical drawings of 928 gearbox?
Thank's in advance!
1967 Bug
Old January 17th 2006, 00:30
Sorry, no. Most of my attention is on the 901 series boxes.
Old January 17th 2006, 03:48
C'mon! There must be someone out there who knows will that thing fit in T1 tranny
1967 Bug
Old January 18th 2006, 05:53
Bruce2 Bruce2 is offline
I'm guessing from your sig that you have a 67 Bug, and it is swing axle.
A 928 diff is not even close to your swing axle diff. Why wouldn't you just get the proper VW diff?
Old January 19th 2006, 03:20
You haven't read it all. My Bug is 67', but it has 944 rear suspension so it's a IRS type. Done that allready
1967 Bug
Old January 19th 2006, 03:56
I'll save you some time. There isn't any diff on any other car in the world that is interchangeable with a Bug's diff.
If you want a LSD, just buy a Beetle LSD.
Old January 22nd 2006, 10:39
Thanks for Your oppinion Bruce2
Anyone else knows would that be possible?
1967 Bug
Old January 25th 2006, 18:53
MattKab's Avatar
MattKab MattKab is offline
The splines for the output flanges on a 928 are in the right place but the bigger/T2 size are they not? And centre is centre, we need to know more about what we can't see...
I think bigger bearings, bigger spider and bigger gerth.. 928 doesn't have the space constraint of the rear driveshaft above it. Which is probably common to early VW30 trans +/- a few mm.
T1/T3 diff is a good choice
Matt
Old January 26th 2006, 10:24
MattKab I can't follow You... English is foreign language to me, sorry
What are You trying to say? What do You know about that diff?
1967 Bug
Old January 26th 2006, 14:28
MattKab's Avatar
My apologies MX67,
I think the 928 diff will be bigger in the centre.
Matt
Old January 27th 2006, 04:32
Why don't you post a pic of the 928 diff?
Old January 30th 2006, 05:18
Because I don't have the picture. That is the point of the thread.
I have to buy a whole gearbox first, then strip it down, and then take a picture. Well, if I do that, i dont' have to ask. I'll see if it fits and in which conditions (machining, aligning... etc.)
And if that LSD doesn't fit, I threw 300 euros away. No thanks!
I've asked for the technical drawings, what do you think why?
I appreciate Your concern about My problem. THX for that Bruce2!
1967 Bug
