Old March 25th 2006, 23:13
Hey Trevor, which kit is the one you used for the rear arms front pivots?
Thanx
Chris
Aircooled 4ever
1973 1303 going towards GL
Old March 26th 2006, 16:53
trevorbrady's Avatar
trevorbrady trevorbrady is offline
Chris, if you mean the bushes for the rear trailing arms, then it's the normal aftermarket urethane bushes kit for an IRS bug. The bushes fit the Porsche arms and allow the use of the large diameter bolt from the bug. I suppose you could fit stock replacement VW rubber bushes, but there's no harm in upgrading to the urethane bushes...
Old May 13th 2006, 04:23
alt+f4 alt+f4 is offline
how much longer is the EJ motors compaired to the T4 or the T1's?
Old May 19th 2006, 08:51
Evil Sid Evil Sid is offline
Couple of questions after reading the thread.
There is a lot of talk of widths of Subaru engines, but does anyone have an idea of lengths?
Has anyone considered newer porsche trannys like G64 (993 turbo)? Can the newer water-cooled 996 boxes fit, e.g. G96?
Can the differences you describe by the type of G50 gearbox be summarised by the second set of digits in the box type i.e. G50, G50-01, G50-02, G50-03 G50-50 etc. as I have elsewhere seen references in this context.
And what about the std IRS t1 gearbox - for the cost of a G50 (say £1300/$2000) is it possible to beef up the IRS box to take the same sort of power? (without 5 gears of course)
Cheers
Old May 19th 2006, 13:33
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Damn Sid,
You've obviously got a chop shop or unlimited funds eh?
Old May 19th 2006, 20:18
I just went and measured my 2 litre STI. Its 790 mm across the cam covers and 430 mm from the tit on the variable cam sprocket cover to the mounting face at the flywheel end, I guess a normal WRX would be around 390 mm for the same measurement.
