Old April 30th 2006, 19:37
Typ Vier Typ Vier is offline
Cheap 4 piston caliper alternative
Just swapped the wheels on an 89 Toyota Hilux (4 runner in the US) which I`m wrecking and thought I share this with you.
O.k. its not for the guys wanting to save weight cause its cast iron but the old 944 had cast iron ones too.
The caliper is 230 mm long, 135 mm wide and the disc is 20 mm thick and has a 280 mm diameter. These things run 15 inch wheels.
Wouldn`t be too difficult to fit.
Andreas
Old May 1st 2006, 19:26
The calipers combined with some 944 discs I mean.
Andreas
Old May 10th 2006, 23:10
flat flat is offline
I did a setup with those calipers on some guys' Datsun 510...they're pretty cool and easily available (ie, cheap).
But man, talk about boat anchors...
www.vdubengineering.com
Old May 16th 2006, 05:33
I can only imagine, guess they are about 10 kilos
Andreas
