Old May 17th 2006, 21:26
Russ1302 Russ1302 is offline
Moving Sale!! lots of type 1, type4, and porsche parts.
I'm selling a ton of VW and Porsche Parts. Everything must go. Here is a list of the first batch. I'll be taking pictures and listing these items and more on thE bay, starting Sunday night. If anyone is interested in anything here,
Email me @ russ1302@gmail.com
Parts are located in Milford MI
BMW M3 Oil Cooler
T4 Bus Heater boxes
914 1.7L heads Used
T4 1.7L Head Used
90mm T4 Domed Pistons with pins
94mm flat top Piston Cylinder set
90mm domed Piston, Cylinder set
911 fan shroud (not for vw engine)
914 heat exchange
T1 Dual ports head tins
911 shifter
Corvair tensioner pulley
6 disc cd changer
Empi Shifter
944 spindles
71-72 super front fender
71-72 super rear fender
71-72 super engine lid
Toyota MR2 Fan
Engine Case
944 Stub Axle
944 Torsion bars
D jetronic system
914 trans hanger
914 Flywheel 2.0 215mm
914 Pressure Plate 215mm
914 Clutch Disc 215mm
Super beetle Rack and Pinion w/ tierods
66mm T4 cranks
stock cams w/gears
T1 cam gear
911 Shift rod
914 tail shift
901 nose cone and shift rod
901 Tansaxle seal kit
Weber DCNF Parts
914 engine case
914 Flywheel 210mm
set of dual solex and t4 manifolds
Old May 17th 2006, 21:59
bow's Avatar
bow bow is offline
those 94mm pistons type 1 or 4 ? how much if it for a type 1
YEAH ITS GOT A HEMI
Old May 17th 2006, 23:37
They are Type 4.
Old May 18th 2006, 08:18
bow's Avatar
bow bow is offline
are willing to part with just the pistions
YEAH ITS GOT A HEMI
Old May 18th 2006, 10:50
If I can't sell them as a set I'll split them up.
Russ
Old May 18th 2006, 10:55
petevw's Avatar
petevw petevw is offline
911 11-blade alternator/fan?
'72 super
'65 bus
'52 split
Old May 18th 2006, 12:22
bow's Avatar
bow bow is offline
ok thanksif youdont sell them pm me thanks
YEAH ITS GOT A HEMI
Old May 18th 2006, 23:10
jrinlv jrinlv is offline
how much for the 914 heads, engine case and the 210 flywheel? Thanks JR
Old May 19th 2006, 22:37
Pillow's Avatar
Pillow Pillow is offline
>94mm flat top Piston Cylinder set<
Interested in the pistons if Bow passes. No cylinders needed though.
Thanks,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 20th 2006, 04:31
Karmann Karmann is offline
How much for the Super beetle Rack and Pinion w/ tierods?
Regards Morten
Old May 23rd 2006, 20:55
bow's Avatar
bow bow is offline
gord head you can have em pillow
YEAH ITS GOT A HEMI
Old June 7th 2006, 15:06
Pillow's Avatar
Just checking to see if this stuff is still available?
Adrian Pillow
