Old June 25th 2006, 22:43
BLS BLS is offline
How do I find the year of my car?
How do I find the year of my car? I was told it is a 73 but not 100% sure. It has run roof and atm I dont have a title =(. I apped for it and it will be in my hand soon.
Old June 25th 2006, 23:07
EvilAngel's Avatar
EvilAngel EvilAngel is offline
If you still have the original engine i guess you can check it out by engine number. There are several databases on the internet that can tell you the year based on the engine number, or sometimes, chassis number.
________________________
1990 Mex-Spec GL Bug "The Blue Flame":
Engine: Planning Stage
Transmission: Planning Stage
Suspension: Front: 3/4 swaybar w/UrethaneBushings, Dropped Spindles. Rear:CB Camber Compensator. Lowered 2 splines
Brakes: Front Brakes: 280mm solid rotors, two pot calipers. Rear: 280mm solid rotors, 1 pot calipers w/ebrake
Old June 25th 2006, 23:55
Mikey's Avatar
Mikey Mikey is offline
A picture would be great, the vin would be even better. The engine number could be right, but you don't know if they changed the engine case at one point in it's life.
Mike
'04 R32 Tornado Red
Old June 26th 2006, 22:16
BLS, its a '73 STD bug if the VIN starts with 113, and if its a super 133
Old June 27th 2006, 01:15
BLS BLS is offline
Its 133 woots. Thx.
Old June 27th 2006, 02:35
alt+f4 alt+f4 is offline
its also a 73 if it has the curved windheild with the round rear tail lights and skinny bumper holes with solid bumper brackets. also will most likely have 3 bolt struts .
Old June 27th 2006, 13:54
BLS BLS is offline
It does have 3 bolt struts. Im hoping to have the body off this week end to start working on the pan rust.
Old June 30th 2006, 17:21
Chris Percival's Avatar
In the UK you can just write to VW UK with your vin number, and they will tell you when it was made..
Old June 30th 2006, 18:15
choconito choconito is offline
check this link:
http://www.abvwc.org.uk/vw_vin.htm
