Old June 16th 2006, 18:16
That should take care of it!!! I'm really impressed that you're able to run your shifter cables through the shifter tunnel. I have to run mine outside due to the position. Your coolant lines run under the motor and up the back?
Old June 16th 2006, 20:24
adaptorman adaptorman is offline
Talking
im hopeing so but a bit woried about if i shud weld some strength to heater channels?year cables bend nicely and work had to extend then about 3foot in the tunnel?,the heater tubes i wasnt sure were to run them ,and didnt want them up and down ,so thought use the centre chassi tunnel and weld too lenghs of wide box shud help strengh as well?any little ideas are welcome had to rearrange the rear wheel archers 2day they now 20inch wide ether side
IMG]http://i6.tinypic.com/14mct8m.jpg[/IMG]
Old June 18th 2006, 11:31
yearh be nice i can understand what u mean an say, i like things to be right plus it be classed as a kit car (q plate then tests and inspections by vosa/dvla )so work as stopped (its time to dismantal the idea nice while it lasted thanks all for your coments
Old June 18th 2006, 16:43
LLVWGL LLVWGL is offline
What? you are going to dismantle it?
Old June 18th 2006, 17:34
yep found a chap whos wanting engine (im a bit pissed off but theres always something else i reckon ) nice while it ladted (got voza poeple coming 2moz just to see what they say?lucky only stands me at 80quid (thank god i ant got 1000s sat in it,ill let you know the outcome
Old June 30th 2006, 20:52
we have good news didnt need a sva (few)as i got enoegh pionts to get it on the road ,so i was very happy so started with a few engine mods and weldind etc
a few pics here (its now a monster 340bhp remaped ecu,bigger turbo, and thought id put a dumpvalve on it too
remaped ecu(inside)
nice new big turbo
Old June 30th 2006, 20:53
rad fitted and piped up
Old June 30th 2006, 20:57
did my own drill and tapped discs
Old June 30th 2006, 21:04
header tank and cooling system sorted
front end all welded up
shorternd my driveshaft
rear wing weled up
Old June 30th 2006, 21:11
didnt want to cut it but had to be done (ok 4 a first attempt with angle grinder lol
Old June 30th 2006, 21:31
and a video of it runing (hope you like it)couldnt rev it higher as theres old biddis nextdoor and wasnt water in the lump back then lol
http://video.tinypic.com/player.php?v=141nnk4
Old July 1st 2006, 03:38
I'm sure you'll sort a way of getting cool air to the rad without cutting the bonnet like that, I guess it's OK to debug it...
So, when's the first drive?
Rich
Old July 1st 2006, 04:50
Rich
it takes a lot more air to cool then ur std bug/scooby lump?and as it had the long bonnet not the later short type so couldnt use/fit a airscoop under the car,plus its very low lol,some work was done before i bought e.g lowerd,deseemed ?test drive a while yet matey but ill keep pictures etc coming and youll no when the time comes
Old July 4th 2006, 17:17
couple more here cooling system done
90percent of welding done,a new type assembly is next ,as the old aircool idea is no good?
Old July 9th 2006, 15:37
few more home made jobs here
