Old July 16th 2006, 14:44
Jim Hunter Jim Hunter is offline
To Steve C
Hello Steve,
I am doing a 930 installation in a 1303 currently and as the bellhousing is identical to g-50 I would like to ask you what have you done about the rear trans mounts ? The oem beetle does not fit and required major welding to flatten the area any idea ???
Rgds,
Jim Andritsakos
Jim Hunter
74 1303 (GL project) *SOLD*
73 1303 (GL project II)
(VW T3s for sale.Panels, 2wd and Syncros)
Old July 20th 2006, 03:52
Hi,
if the bellhousing looks like the 915-bellhousing, then I can offer you the usage of my new laser cut steel traverse with 2 aluminium blocks that have the shape of the bellhousing. The traverse comes with 4 rubber blocks (2 for vertical movement and 2 for horizontal movement). Give me your mail-address and I´ll send you pictures of this part.
Martin Bott
Bug @ 5-Speed
www.bugat5speed.de
Old July 24th 2006, 10:46
Im moving my motor forward 100 mm, so Im going to use the stock Subaru mounts and bolting them to a bracket on the frame horns. Im using the stock G50 front mount, a Berg style mount in the middle so that the box dosent drop down with the motor removed.
Progress has been a bit slow, doing lots of work around the house.
Old July 31st 2007, 17:03
speedy's Avatar
speedy speedy is offline
Hi steve, i wondered how you were getting on with the gearbox,
jon
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old July 31st 2007, 19:47
I've done as much as can on the pan for the time being, I'm getting the body ready for paint now, I only have tiny garage as we live on the edge of a cliff. I have to leave the body and pan together for as long as I can. When the body comes off I can get in and do some of the welding that still needs to be done in hard to get at places. The shift lever is in, I need to muck around with the shift rod when the body is off and I can pull the box in & out easily.
Thanks for asking, Steve
