Old December 16th 2002, 03:55
vujade's Avatar
vujade vujade is offline
Fitting Porsche Brakes to a 1302
I have a 71 1302 Super. I would like to adapt Porsche Brakes to the front and rear. I know that you can adapt 944 suspension to the rear of any IRS & to the front of a 1303.
So what about the front of a 1302?
What can be done?
I have seen some that adapted a beetle hub to a porsche rotor, is this an option? what is entailed?
Please help....I want to know what my options are!
WinterJam 2010
Old December 16th 2002, 16:59
Jim Andritsakos's Avatar
Hello Vujade
You have mail!
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
Old December 16th 2002, 18:30
Thats a good question Joe.
Old December 17th 2002, 03:53
vujade's Avatar
I am currently talking with Jim on a few alternatives for adapting Porsche disc brakes to a 1302 other then upgrading to the later 1303 suspension... I will keep everyone posted
WinterJam 2010
Old December 19th 2002, 08:21
yetibone's Avatar
yetibone yetibone is offline
We are about to try '87 944 hubs, calipers, and rotors on the
front of a "71 SB (after striking out with CB's disk conversion)
I'll let you know how it goes.
Yetibone
Old December 19th 2002, 08:39
vujade's Avatar
please do keep us posted
WinterJam 2010
Old December 19th 2002, 18:37
Pillow's Avatar
Pillow Pillow is offline
http://www.kerscher-tuning.de/kaefer/detail.php?id=110
Would that work to mount a Super with 944 spindles?
Sorry I do not know the difference between a 1302 and 1303. Use US terms LOL
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old December 19th 2002, 18:44
Adrian
The 1302 is the flat windowed 71-72 Super and it has a three bolt strut, mid year 73 they went to a two bolt strut which looks amazingly identical to 924/944 struts and it isn't difficult at all to convert to a 944 spindle.
Nick
Old December 19th 2002, 20:23
yetibone's Avatar
I think that the way to get a 1302 ('70 to early'73 SB) to work with 944 spindles is to get a pair of lower control arms from a 1303 (late '73 on up) I just found a set in Durham NC. 1303 control arms have ball joints that press into the control arms from the bottom, and have the ball stud pointing upwards.
944 spindles look much like late SB spindles, except they have provisions for mounting a caliper directly to the steering knuckle instead of to an adapter. I intend to use the 944 struts as well, except with SB springs as the 944 springs are much too stiff for a rear engine car, and with stock 1302 strut crowns.
The problem I am experiencing is the difference in the ball joint ball stud diameter. 944 ball joint ball studs are larger than 1303's.
Same is true with the tie-rod end ball studs. Anybody know what ball joints, and tie-rod ends to use?
yetibone
Old December 19th 2002, 20:36
Michael Ghia's Avatar
Cool
Get in touch with CSP. I think they're making balljoints to replace the standard 1303 bottom balljoints but they're the correct size to fit your 944 spindles.
Mike Ghia
Old December 19th 2002, 20:46
yetibone's Avatar
Cool banannas!
Thanks for the reply Michael. How do I contact them? Do they have a website?
Yetibone
Old December 19th 2002, 21:13
Cool
Yeti... I got it wrong... it's Kerscher who make them.
MG
Old December 20th 2002, 14:01
Pillow's Avatar
Thanks for the clarification Supa!
Adrian Pillow
Old December 20th 2002, 18:33
Pillow, sorry mate... didn't see your post for looking... I was too busy flicking through to answer
Cheers bud
MG
Old December 20th 2002, 21:29
yetibone's Avatar
Thanks for the link Mike. I've contacted them and just heard back today.
The closest fit I could find for those ball joints are ones for a Dodge Omni (EEK!):toilet:
Oh... yeah, I also found out that the spindles and hubs we are using are from an '86 944, not an '87 like I thought before (I've honestly never dealt with any Porsche parts before other than working on a '76 914 2.0, so I didn't know) The brake rotors bolt on the back of the hubs we are using. I don't think this should cause any problem though.
