Old October 14th 2006, 18:49
bow's Avatar
bow bow is offline
rear sway bar?
is there a rear sway bar avaiable for a 73 irs super?
YEAH ITS GOT A HEMI
Old October 14th 2006, 22:31
Sway-away, and whiteline make'em. Aircooled.net has the whiteline, and sway-away. You can also get the sway-away from almost any VW parts shop. Just look for '68 and later typeI IRS... the rear is the same for STD's and SB's.
Old October 15th 2006, 13:32
bow's Avatar
bow bow is offline
thanks ill check em out
YEAH ITS GOT A HEMI
Old October 16th 2006, 12:15
flat flat is offline
The 944 rear bar is a relatively easy swap onto a VW. A little welding required.
www.vdubengineering.com
Old October 16th 2006, 14:15
oasis's Avatar
oasis oasis is offline
From the "Price List" page at TopLine.
87-0314A ... Sway Bar, rear, all IRS, each ... 84.95
I have one; easy to install even for a technoklutz.
Old October 16th 2006, 14:24
OldeFahrt's Avatar
OldeFahrt OldeFahrt is offline
Unless you use your car for nothing more than cruise night, go with the adjustable Whiteline. It's more money, but well worth it. The 3/4" bars just don't cut it.
Aircooled Road Racers
www.shoptalkforums.com/viewtopic.php?p=768795#768795
Old October 16th 2006, 14:37
oasis's Avatar
I don't know anything about Whiteline and it may very well be the cat's meow but the "cruise night" comment speaks volumes -- and not about any of the products suggested herein either.
Old October 16th 2006, 14:45
OldeFahrt's Avatar
Glad you caught that. All I'm saying is that if you involve your ACVW in any competitive situation that includes curves, it's going to take a fat sway bar to keep your patch on asphalt. The adjustability is nice for tuning your set-up. A notch here & there really makes a difference.
Old October 17th 2006, 18:58
bow's Avatar
bow bow is offline
my car is a daily driver/racer with upgraded suspension and an extra motor. its a pure daily driver in the inter and daily/racer in the summer. u guys know the whole heater box thing gets kinda cold here so i put my 1600 in there
YEAH ITS GOT A HEMI
Old October 18th 2006, 08:06
OldeFahrt's Avatar
Try standing in the "Air Box" at Arnold.
I'm running 22mm sway front & 24mm rear with 28mm rear tortions and Red Koni's. Poly bushes all around. It's a firm & solid ride without being harsh or rough. The kicker is that it corners flat at limit. I wanted a cone carver & I built one. The set-up really works for me.
Old October 18th 2006, 16:19
andy1303 andy1303 is offline
How do you adjust the adjustable whiteline sway bar?
Old October 18th 2006, 17:59
OldeFahrt's Avatar
There are 4 holes in each end of the sway bar. The closer to the end, the more leverage the suspension has on the bar. Choke up on it & the bar gets more leverage. This pic is the old style, but it will give you an idea of how it works.
http://www.aircooled.net/new-bin/vie...18200699119647
Old October 19th 2006, 02:34
Nice one. Thanks.
