Old April 9th 2007, 09:43
JiI's Avatar
JiI JiI is offline
915 rod thingy
What is the rod for that comes out of the driver's side front of the 915 transmission? (circled in the picture.)
Does anyone know if you can hook up an early, aftermarket (Red urethane) VW shift rod connector to the shift rod on the 915 tranny? Thanks!
JiI
"If at first you don't succeed, give up, there's no sense in making a fool of yourself."
Old April 9th 2007, 10:44
CLKWRK's Avatar
CLKWRK CLKWRK is offline
That rod sticking out of your 915 looks like it is for the 911 throttle linkage.
The urethane vw aftermarket shift coupler fit on my 901 transmission no problem, in my ghia I did use a dune buggy shortening kit to dial in the rod length
Bryan
GL ghia restoration:
Old April 9th 2007, 11:41
JiI's Avatar
JiI JiI is offline
Throttle linkage? Does it have anything to do with the transmission? Is it needed?
JiI
Old April 9th 2007, 11:43
CLKWRK's Avatar
you can remove it
Old April 9th 2007, 13:25
JiI's Avatar
JiI JiI is offline
Thanks! I'll be cleaning the new tranny this weekend!
JiI
Old April 22nd 2007, 15:36
Yeah, I grinded that thingy off too.
Old November 12th 2007, 12:01
I have the same issue. After cutting this off, do you have to worry about anything falling into the gearbox internally ?
Old November 12th 2007, 12:12
Sandeep,
I am sure you have also noticed that that rod seems to be jammed stuck in there. I don't know how it is actually inserted into the tranny case, but considering its function (911 throttle linkage), the remains falling inside the case, would be highly unlikely. Its probably glued in there or s/th.
I sure would rather take it out the way it was put in there to be honest...
(also since the G50 has that same rod..). maybe gripping it and twisting the rod back and forth?
Old November 12th 2007, 21:24
Mine was threaded. (M8x1.25mm) It must not have been to hard to remove...as I remember taking it off, but not HOW I did it.
Old November 12th 2007, 21:50
Trogdor's Avatar
Trogdor Trogdor is offline
removed with a screwdriver in the hole and turn
My button
Old November 13th 2007, 09:51
I was going to post and say mine had a hole in the shaft, screwdriver in the hole to unscrew it but trogdor beat me to it.
Old November 13th 2007, 16:39
I checked and it srews out on a G50 as well (grip-tool, no screwdriver head present), but it also started to leak tranny oil immediately as well...so the hole goes through the case wall.
Not sure if this is the case with a 915 tho.
Old November 13th 2007, 17:14
I can confirm that on a 915/62 that this hole is actually a threaded boss that does not extend into the case.
Possibly this is the case for all 915 gearboxes.
Old November 13th 2007, 21:53
The mounting boss on my '85 915 does not open into the case either.
