Old May 31st 2007, 10:57
redhot redhot is offline
Digital gauges
Hi,
Going to install some gauges in my car during the summer. The best option I have found so far by thinking, is to install digital gagues behind the dash-grill on the left side of speedo. Keeping the stock apperance when not using the car and having the option of turning them on/off.
Also considering just having them on a small pod underneath the dashbord, but hoping it can be done behind the grille.
1) Does there exist a combination gauge with oil temp & pressure? In digital
2) Any opinions on the setup?
Old May 31st 2007, 11:41
tom'72's Avatar
tom'72 tom'72 is offline
Dakota Digital has several digital gauges. I got mine from them.
Old May 31st 2007, 12:13
Looked good, only thing is the size of the housing etc. What would be perfect is a display with two areas. And just a slim square piece. Like a flat LCD screen sort of.
Old May 31st 2007, 12:46
Dark Wanderer Dark Wanderer is offline
Do they work great? Are they accurate?
Old June 1st 2007, 08:57
tom'72's Avatar
wel, the do work but when the numbers on the display change very fast (hard acceleration for example) it's not as clear to see as a conventional gauge. The look of these gauges is very different from others, that's the main reason I got them.
